k24a2 swap vs k20a2
Old Sep 6, 2005
Dark2k1's Avatar
French ass K20a2 powered
Dark2k1 is an unknown quantity at this point
k24a2 swap vs k20a2
Ok... I ever swap myself a k20a2 in my car, So I gonna make a k24a2 swap for one of my friend soon...
I want to know if someone have the C101 connector wiring for the TSX (I only have Civic and RSX one).
And someone know if a k24 subframe gonna fit in an EM2 or I must found a k20 subframe.
So if I MUST know something about the difference in a k24 than a k20...don't be shy
Thank in advance...
Old Sep 6, 2005
HondaLuver's Avatar
Its a celebration bitches!
the wiring is the almost exactly the same as a rsx S. i used the k20 subframe. what car are you going to stick this in. with mine, i needed to customise the passanger side mount, the others fit perfectly
Old Sep 6, 2005
Dark2k1's Avatar
We gonna swap it in a Em2 with enjo mount (this kit is bolt on for k24 too)
Do you know if the intake manifold is bigger on a K24a2..?? everybody doing this swap seen to put the PRB or PRC head.
For the subframe... I don't know in the US... but in Canada found a used RSX or SiR (CDN Si) subframe is like a pain in the ***. But a Accord or CRV is pretty enough and really cheap. But we don't know if this gonna fit...
Old Sep 6, 2005
HondaLuver's Avatar
the intake manifold on a tsx, it has longer runners... i used a type R... its bigger, but i can't realy compare it... they put those heads for better flow and the cams.
use a base, type S or a Type R manual subframe. im not sure about those others
Old Sep 6, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
dont use the k24 subframe cause a side by side comparison when i was at the junkyard showed differences.... unless you want to try otherwise and post your results
Old Sep 7, 2005
Dark2k1's Avatar
Ok so do you think the TSX intake gonna clear the engine bay near the hood sketch.... My k20a2 is only at 1/4 inches....A type R intake is a better choices ??
Thank for the subframe....we gonna search a k20 one
Old Sep 7, 2005
HondaLuver's Avatar
it might fit, the runners go down, and the type R fits perfectly
Old Sep 7, 2005
Dark2k1's Avatar
OK thank
Old Sep 7, 2005
if a dual intake runner can fit in our cars i dont see why the tsx wouldnt fit
Old Sep 7, 2005
HondaLuver's Avatar
i dont' think the dual intake will fit
Old Sep 8, 2005
damn right it did.. i had it in my car... i had to fricken cut the frame by the radiator so it could fit... took that out and finally put in a different manifold... now i got a big cut right where the manifold used to be.. sucks ***... wish i just swapped out the manifold earlier
Old Sep 8, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
why did you swap with the tsx manifold? ... now you gotta mess with dbw
Old Sep 8, 2005
dbw???
Old Sep 8, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
drive by wire throttle ... instead of cable
Old Sep 8, 2005
mines is a cable throttle... not dbw
Old Sep 8, 2005
so you can see it for yourself the dual intake runners
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
