projector headlights
Crayons taste like purple...
I've looked at getting the projector headlights and I've been wondering: seeing as they have more openings in them does that mean new bulbs?
as in some have 4 holes so does that mean hi..low..parking..turn?
cuz the 01's use dual beam 9003...and that means new kind of wiring would be needed...
the projectors has the angel eye as low beam and the other one high beam. well... depends which projector your looking at. the parking and turning signal also. oh yeah they have different bulb for the high and low beam. if its the tyc than all the bulbs are different but the parking light i believe.
Originally Posted by Shroomster
does that mean buing new lights and wireing and harnesses?
nope.... if you buy the tyc ones, its just plug your factory into them. they have slots to where its like factory and you just clip them on. on the other hand, if its the other kind of projecter, you can use your factory bulbs
(signal and parking). but not a perfect fitment. might have to use some electrical tape and tape around the bulb so they can hold still instead of being loose and dangling around.
Originally Posted by LowSky
the tyc are as plug and play as you can get.. the ebay ones i'm not so sure about
Most all use H-1 bulbs for hi and low beams, the park/turn bulbs usually need an adapter if you have a coupe!
Originally Posted by pon55
Even most e-bay ones have a harnes included!
this why I'm kinda confused everyone is talking about H-1 lights....Am I the only one that has 9003 dual beams? do the H-1's take the place of 9003's? do they have the same design so that they fit in the O.E.M slip and housing?
the h1 replace the 9003. the projectors will have a seperate plug that you plus your factory harness into.
ahhhhhhhhhhhhhhh now it makes sense
i have twin halo angel eye projectors on my civic, if you get prjectors, they should come with the light already in them , all you have do is plug in the stock harness into the one on the back of your lights , it should come with one that fits to it. and , if they dont send you the parkin lights , put your stock ones in there and your done , then put your car back together
In any case OEM are far brighter then these projectors, unless they have HID's.
bright isnt the term, they dont light up as much side to side, mine made a W pattern, leaving a "blind spot" on each side.. they are terrible..
DONT.
DONT.
Ashho-san 7thgen Ninja
well mine lit up more on the sides. of course i think they are also aimed outward a little more. but no, they arent as bright. overall i am satisfied with mine for what i paid.
Originally Posted by civicstylez
ive heard getting projectors isnt a good idea supoosely they leak and melt and the led goes out fast..... i was thinking of gettin them any suggs?
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
