projector headlights
Old Sep 6, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
Question projector headlights
I've looked at getting the projector headlights and I've been wondering: seeing as they have more openings in them does that mean new bulbs?
as in some have 4 holes so does that mean hi..low..parking..turn?
cuz the 01's use dual beam 9003...and that means new kind of wiring would be needed...
Old Sep 6, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
the projectors has the angel eye as low beam and the other one high beam. well... depends which projector your looking at. the parking and turning signal also. oh yeah they have different bulb for the high and low beam. if its the tyc than all the bulbs are different but the parking light i believe.
Old Sep 6, 2005
shroomster's Avatar
does that mean buing new lights and wireing and harnesses?
Old Sep 6, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
the tyc are as plug and play as you can get.. the ebay ones i'm not so sure about
Old Sep 6, 2005
nope.... if you buy the tyc ones, its just plug your factory into them. they have slots to where its like factory and you just clip them on. on the other hand, if its the other kind of projecter, you can use your factory bulbs
(signal and parking). but not a perfect fitment. might have to use some electrical tape and tape around the bulb so they can hold still instead of being loose and dangling around.
Old Sep 6, 2005
pon55's Avatar
Even most e-bay ones have a harnes included!
Most all use H-1 bulbs for hi and low beams, the park/turn bulbs usually need an adapter if you have a coupe!
Old Sep 6, 2005
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
the ones i got i only had to move the parking lights and blinkers from the original light housing. The projectors came with high and low beam bulbs
Old Sep 6, 2005
shroomster's Avatar
this why I'm kinda confused everyone is talking about H-1 lights....Am I the only one that has 9003 dual beams? do the H-1's take the place of 9003's? do they have the same design so that they fit in the O.E.M slip and housing?
Old Sep 6, 2005
the h1 replace the 9003. the projectors will have a seperate plug that you plus your factory harness into.
Old Sep 6, 2005
i meant plug instead of plus.
Old Sep 6, 2005
shroomster's Avatar
ahhhhhhhhhhhhhhh now it makes sense
Old Sep 7, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Sep 24, 2005
eziey's Avatar
eziey is an unknown quantity at this point
i have twin halo angel eye projectors on my civic, if you get prjectors, they should come with the light already in them , all you have do is plug in the stock harness into the one on the back of your lights , it should come with one that fits to it. and , if they dont send you the parkin lights , put your stock ones in there and your done , then put your car back together
Old Sep 24, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
if your considering getting projectors budget about $1000 for a proper HID retro fit, otherwise when you get these projectors, they will look cosmetically nicer, but the light output on most if not all projectors not equiped with HID, is lacking at best.
In any case OEM are far brighter then these projectors, unless they have HID's.
Old Sep 25, 2005
Ashhole's Avatar
ill agree that overall brightness is less than stock housings, but the area the lit up by the headlights increased
Old Nov 3, 2005
civicstylez's Avatar
civicstylez is an unknown quantity at this point
ive heard getting projectors isnt a good idea supoosely they leak and melt and the led goes out fast..... i was thinking of gettin them any suggs?
Old Nov 3, 2005
shmik1's Avatar
bright isnt the term, they dont light up as much side to side, mine made a W pattern, leaving a "blind spot" on each side.. they are terrible..
DONT.
Old Nov 3, 2005
Ashhole's Avatar
well mine lit up more on the sides. of course i think they are also aimed outward a little more. but no, they arent as bright. overall i am satisfied with mine for what i paid.
Old Nov 4, 2005
dirtySAMURAI's Avatar
I log in from time to time
that's only if you get projector headlights with halos. the projectors used in aftermarket projector headlights are crap. don't buy it unless you plan on using your car ONLY in the day time, or if you're into car shows. if you want to drive at night, be prepared to crave HID retrofit.
wingsfan19
Oct 1, 2015 03:45 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
