Question about synthetic blends oil.
Is the synthetic blend oil and exact ratio of 50-50 of full synthetic and conventional oil? If not, what is the ratio of the mixer?
Also, would it be safe to simply mix the two different oils together, thus hopefully cutting down the cost but still having some extra protection from the properties of synthetic oils.
DIY King
If it's true that you have to keep using it, then it sounds like they don't want the oils to mix together. Hum... I think there is a definition of how much synthetic oil and how much natural oil goes into the making of a synthetic-blend oil. Maybe there is some lower percentage set so that you can't add a tiny drop and give a certain product a better name. Any lawyers in here know for sure? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
To answer any questions regarding oil blends and mixes...It is ok to mix oils such as synthetic and natural oil. However the mix ratio should be more like 80 to 20 synthetic to natural. The reason is that synthetic oils are made to be frendlier towards the environment, and there isnt quite the same ingredients in synthetics as regular oil. Synthetic oil wont seperate like oil in water when mixed w/ natural oil, but to be on the safe side stick to one or the other. If I am low on cash come oil change time I prefer Amsoil or Mobil1
You wont gain anything performance wise unless you run NOS, being your engine gets hotter quicker. DUH The reason synthetic is more expensive is that it doesnt cost a lot to recycle or dispose of so the company needs to make that extra bit of money back somewhere, and the fact that synthetic actually keeps your engine running smoother and cooler. If you prefer natural oils, stay away from Havoline, and brands like PDQ brand or Dollar General...
Those kinds are cheap for a reason...THEY SUCK, and burn up quicker in your engine...So its all up to what you prefer...Oh to answer that one question about weights of oils. 10w30 is a thicker oil to be used in the summer. 5w20 which is what is recomended by honda is alot thinner and is suppose to be used in winter months. Makes sense huh...The colder it is the less you engine wants to move its parts...So why not make it easier with thinner oil. I use 5w20 personally year round. I think I get a bit better gas mileage...but you will have to experiment...good luck
Those kinds are cheap for a reason...THEY SUCK, and burn up quicker in your engine...So its all up to what you prefer...Oh to answer that one question about weights of oils. 10w30 is a thicker oil to be used in the summer. 5w20 which is what is recomended by honda is alot thinner and is suppose to be used in winter months. Makes sense huh...The colder it is the less you engine wants to move its parts...So why not make it easier with thinner oil. I use 5w20 personally year round. I think I get a bit better gas mileage...but you will have to experiment...good luck Thread
SidCivic
17
Aug 23, 2015 03:14 AM
Jul 12, 2015 11:54 AM
1khilari
Jul 9, 2015 08:12 PM
BootyDo
Jul 7, 2015 06:06 AM
