OBX Throttle body spacer and AEM CAI
Old Sep 1, 2005
D17rider's Avatar
D17rider is an unknown quantity at this point
Question OBX Throttle body spacer and AEM CAI
Hey, I would like to know if my hood would close properly if i put the OBX TB spacer in along with the AEM CAI, let me know if anybody has this done? Thanks
Old Sep 1, 2005
maybe? you gotta measure it. Look up the measurment specs o the tb spacer, then cut a piece of sponge and tape it on your intake. Put some kind of paint or glue on the top of the sponge and close the hood. If it touches, you know it won't fit.
Old Sep 1, 2005
diskreet's Avatar
does the TB spacer do anyhting other than be a b!tch and make hp worse. its still a D17 so w/o a turbo there isnt much hope.
Old Sep 1, 2005
nope doesn't work. our intake mani will cancel any air that gets swirled or whatever it does. Prolly works for old carb engines.
Old Sep 1, 2005
diskreet's Avatar
ya i was gunna say it seems pretty useless to me but w/e if you want one go ahead and try it.
Old Sep 1, 2005
mclean987's Avatar
mclean987 is an unknown quantity at this point
i had one installed for a while and the car felt much etter at lower revs i got i/h/e high flow cat, short ram though , i removed it after and the car felt much slower so i put it back it really does make a little difference not no big difference though
Old Sep 1, 2005
i kinda wanted to try one but my intake would touch the hood and I don't want it getting scraped up.
Old Sep 1, 2005
tuner04civic's Avatar
spell check pwns you
with aem's cai i dont think u can have a t/b spacer, will hit hood. But i would double check and measure it if i were u
Old Sep 1, 2005
AlienX's Avatar
AlienX will become famous soon enough
ppl have made it fit with a little cutting..
Old Sep 1, 2005
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
It will fit with the stock intake. It will also fit with the "Racer Design" intake. I have this setup now. It works better than I expected.
Old Oct 12, 2007
2k1_Stockie's Avatar
2k1_Stockie is an unknown quantity at this point
Re: OBX Throttle body spacer and AEM CAI
Its probably not seated right and causing some kind of vacuum leak. Theres no way you can install it wrong, u cant flip it over and mount it. Just make sure bolts are tight and gasket is seated right. If there is no gasket, thats where ur problem is. Only other thing i can think of is your idle air control valve is sticking.
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
