I'm searchin and searchin and I can't find any info on AC removal!
Old Aug 7, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Can some one help me out? or is my best bet to buy a service manual? I mean what belts will I need after the ac is removed? Also... is it a good idea to remove the PS as well at the same time? Or will I hate that?
Old Aug 7, 2005
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
First of all, why would you want to remove your AC?
Second what belt are you talking about?
I've remove a few times, and it is a pain in the *** to take out and put back together. If you're not careful removing it, you can crack the high pressure aluminum piping. Also ur gonna need to spend some more money buying new AC coolant afterwards.
Old Aug 7, 2005
Blahman240's Avatar
I never use it... so I figure might as well save some gas. And why do I need ac coolant? I'm not using the ac... you mean to reinstall?
Old Aug 7, 2005
Blahman240's Avatar
anyone help?
Old Aug 7, 2005
diskreet's Avatar
how could you not use it. we've had over 90 degree weather for the past few months almost 1 of every 2 days!
Old Aug 7, 2005
Blahman240's Avatar
windows down.
Old Aug 7, 2005
diskreet's Avatar
i try that but its too hot for me. i am always driving in hazleton though so im never getting over 45. to and from work i put down the windows since its under 4 miles away but any other times im dieing!
Old Aug 8, 2005
fallout's Avatar
...Ok then... Dont know why ur doing this, but i'll help you out.
There are 2 ways to do this.
1. To remove the AC, the high and low pressure pipping are on the driver side, top/bottom right corners. The bolts are screwed from behind the AC, so you'll need to remove it from the inside. (Yes, this is the pain in the *** part). You'll need pretty small hands and ratchet. If you dont care about putting it back or the well being of it, you can pull it out about an inch and it'll give you more room to work with. Unscrew the bolts until you see/hear/feel the coolant stuff leaking out. Be careful not to let the coolant hit ur face! Once all the coolant has been drained, completely remove the bolts and yank that sucka out.
2. The other way is much easier. Remove the high and low pressure pipping from the AC compressor. (Let coolant drain before removing the bolts completely.) Now the AC can be pulled out a lot further so you can remove the screws from the pipes. This way you dont have to squeez your hands between 2 inches of space to work with.
Old Aug 8, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
its not gonna make any diff w/ savin gas. aslong as you dont turn on the AC, the AC pulley will turn w/o any effort.
Old Aug 8, 2005
streetglower's Avatar
there is no such thing as AC coolant. It is refrigerant and you cant just start opening up lines and releasing refirgerant into the atmoshere. It is against the law. If a neighboor sees you releasing refirgerant into the atmoshere and takes pics and calls the EPA, you could be fined up to $10,000. It is very unlikely that will happen, but it has before. Whenever someone has to service the AC and replace a component, the refrigerant has to be evacuated from the system. Besides, if you pull off one of those high pressure lines, you could be pierced with refrigerant. hence the words HIGH PRESSURE. and refrigerant doesnt just pour out, once it hits the air, it is gas.
Now if you want to remove the AC unit, have the system evacuated first. Then you can start pulling off lines and components.
Old Aug 8, 2005
2K1Civic17"Gabe's Avatar
hehe, I didnt realize that myself. Yesterday, I started taking the lines, off, than I hear, PSSSSSSHHHHHH loud as hell. For about 4 minutes. I shoulda known better, but couldnt even get my car anywhere. no valve cover, turbos off, IM off (almost), fuel rail, everything is apart, so I had to. I wont next time, I didnt know it damaged the environment.
Peace.
Old Aug 8, 2005
sweeteli99's Avatar
sweeteli99 will become famous soon enoughsweeteli99 will become famous soon enough
can i buy your AC supplies? depending if everything is in good condition?
i took it out of my car when i was boosted, now NA and its a bitch... i want it back NOW. i have most of the stuff already, just need a couple of things.
you'll need a DX belt its like 15 bucks...everything else is just taking apart, not too hard. it just takes time. if you can't figure it out, i can help further.
Old Aug 8, 2005
Peace.
technically R-134A has a 0 ozone depletion rating, but R-12 has I think a 1 or so ozone depletion rating. Anyway, R-134A doesnt hurt the atmosphere, but the EPA still makes it illegal to release into the atmosphere based on the fact that noone really knows what is in your system. If the EPA came to your house and saw it, for all they know you could have R-12 in there and say it was R-134A. You understand what I am saying I hope. That is why all refrigerant has to be recovered and recycled.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ilgnay
Apr 26, 2010 11:53 PM
LexBoy
Nov 5, 2001 08:00 PM
Mokushi
Nov 1, 2001 02:40 PM
