Washer Fluid Indicator Light Stays Lit
Hi all, just wanted to know if anyone else has this problem. I have a 2001 Civic DX and the windshield washer fluid indicator light stays lit in the cluster. Is there a rpoblem with the sensor or wiring? Anyone with clues or ideas on how to fix this. Thanks
ya did you try filling it? if you did, its prolly just the sensor. Not sure how to fix that tho as its in the washer reservoir. Maybe get a new holding tank from a junkyard.
ok, why do people keep making this harder then it is.
If the light is on, check the simplest thing first. See if you have fluid. 99% of the time there will be no fluid in there is the light is on. If there is fluid, then check the circuit or sensor.
Now if the light doesnt come on at all, then check the light bulb. It is probably burnt out. I dont understand why people always try the hardest things first. Or dont think right.
Blazz
May 25, 2015 10:56 PM
Ma213802
May 18, 2015 07:01 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
