Tires and Ground Clearance?
Old Aug 2, 2005
matt86's Avatar
matt86 is an unknown quantity at this point
I'm about to go for a 2inch drop for my 04 civic vp and first i just wanted to run a couple things by all the pro's. I'm gonna be running some 205/50/16 tires and was wondering if i will have any trouble with rubbing or anything. Also, if i dropped it two inces would i have enough ground clearance for honda to be able to get my car up on one of their lifts? Thanks for any comments
Old Aug 2, 2005
robbclark1's Avatar
Retired suspension supermod.
with a 2" drop you probably won't have enough clearance to drive up a ramp, but you might get on a lift, depending on how small the plates are. We really can't tell you if you will rub or not. You can alwasy roll your fenders and pull in your camber, but it is a guessing game for us too.
Old Aug 2, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Its gonna fall farther because the tires are smaller than stock. 205/55 will run a little higher. Tires change your ground clearance, not the suspension height... and they're important for what will make the car clear and what wont. I really don't recommend going 2". It always ends up more... and your steering rack is going to be in trouble later on.
Old Aug 2, 2005
matt86's Avatar
Thanks for the input you prove a really good point? How far do you think i should drop it in my case?
Old Aug 3, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
are you using coilovers or springs? i have 205/50/16 with a neuspeed sport drop and nothing rubs.
Old Aug 3, 2005
jttegx's Avatar
OMNES AD UNUM
a 1.2-1.7" drop would be milded enough. sport stance.
what exactly are you trying to get from lowering your car though?
id also consider a rear camber kit and an alignment after. front camber isnt an issue on the em2/es1 (civic01+) maybe the ep3 (si hatch)
Old Aug 3, 2005
Xenin's Avatar
i actually needed a front camber kit cuz the mechanic couldnt get the camber right on the front right wheel.
Old Aug 3, 2005
matt86's Avatar
Do you have any pics of what your car looks like?
Old Aug 3, 2005
CLeeNx04CiVic's Avatar
CLeeNx04CiVic has a little shameless behaviour in the past
i got an 04 coupe and im on goldline springs (1.75" drop which settled in at about 2") on 205/50/16 and on 195/60/15 i was still able to go up the ramp (barely, but made it) and lift (no prob)...u should be fine
Old Aug 4, 2005
Xenin's Avatar
Old Aug 4, 2005
matt86's Avatar
looks great
juror
Suspension DIY
Jul 30, 2019 03:28 AM
hondadriver95
Jul 13, 2015 09:43 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Causemo
Jul 5, 2015 06:42 AM
