A/C making car idle low?
My ac was broken in my '03 civic and just fixed it but now i run the ac and the RPMS are below 1000 but when its off it idles just above 1000. the car also jerks at random when not shifting. is this normal?
My car does that too sometimes when I just start it. I know it's not my clutch because I have a Clutchmasters FX100 clutch. Acually it does that sometimes when the AC isn't on. But only when I drive it right after a cold start.
Originally Posted by Bires
No to both things. Your AC should drop your idle, then it should come right back up. The jerk thing...that sounds bad, maybe your clutch is slipping?
Originally Posted by gearbox
Two problems. 1. stock idle without load is 700+/-50rpms. 2. Using the a/c should usually raise idle by 100rpms when its on.
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
tattedlariat
Apr 20, 2015 09:26 PM
dooner24
Apr 14, 2015 07:51 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
