help with 5 lug conversation with vic coilover
i was wondering if the rsx 5 lug converstion will fit with the vic's tein coilover or do i also have to get rsx coilver? because i am plannin to lower my car, and i dont want to get a set of coilover for our vic and then have to get new ones when i do the 5 lug coverstion. also all i have to get is a set of spindles and axles off an rsx and swap them out with the vic rite? and does anyoe know where i can pick up some spindles and axles?
didn't u say u want to swap in the nor cal forum?
might as well do it together with the axles and all.
heck, it might be even cheap if u buy a wrecked rsx than buying engine, tranny, and brakes separate.
5 lug conversions are cool..but..i unno, to me, its not really worth it, only for some really hardcore modders..that want to make their vic just like a DC5, or make a Type R version of their vic. or just have too much money to spend. lol
5 lug con hives u a larger choice of rims. That is the main reason of converting. It has its extra benifits like brakes, and suspension. All in All if u can put the money towards something else, then there really isnt much point converting IMO. You dont need to convert to k20 swap just si axels.
seem lik no one realy answer the question i'm lookin for or understanding...guess i made it too long...ok here the question again...
05 vic tein coilover = will i have to change it if i do a 5 lug conversion?
Originally Posted by k20txem2
To answer your questino NOt you dont have to get the tien coilovers for an rsx. That would bassically cause your car to be out of wack, since they rsx's have a different spring rate to compinsate for the RSX's heavy body. But to get the half shafts to fit in, your just going to have to suck it up and get some off a rsx, proabably local junk yard or sometihng would be your best bet, then your going to mate them with you stock civics. Good luck
To answer your question, you can fit any of the FULL coils you want, but you might have to do some modifying. The mount bolts are 14mm on 01-02 civics and 02 sis, whereas now everything is 16mm. Therefore coils designed for civics will have 16mm bolts which you may have to enlarge using a drill. In addition, the tie rod bolt end is different for DC5/EP3 and the civic. This is an easy fix. All you need it two tie rod ends that fit the coiloves.
Cliff notes - if you have a 7thgen civic tein coilover with 14mm mount bolt holes then you will need to enlarge them. If they are alread 16mm and you don't replace your tie rods, then you should be fine. If you replace your tie rods, you need to swap the civic tie rod ends back on.
Half shaft = drive shafts (go from transmission to stearing knuckle) anyways
Yeah i forgot you do need to change the tie rod end also
and robbclark... if your telling me you can put rsx shock on a civic right now, ide like to see you do it and see how high your car goes. and rsx is a heck of a lot heavyier than a civic, and if they dont use shock or coil overs to compinsate for that what do they use?
If I am wrong, I will gladly admit it.
Hey didnt say you were wrong just double checking. thas all. Its cool. Im not a 100% when i comes to suspension, but all i was saying is he can use the stocker civic if he wanted to or even order for the civic. That i do know. Ive seen it done plenty of times.
If he already has the suspension they why bother. It just takes a little modding to get them to fit.
time for bed for me
time for bed for me
o thnx for the info em2typeflex...i thought you would need the 5 lug to compensate for the new power...but if i dont have to do the 5 lug conversion..then dats great because i dont have to spend extra money and i can get my rims now!
Resurected!! lmfao
Let me get this correct instead of making a a new thread.
02 Civic with Tein SS-P's.
Going to do k20swap and 5 lug swap.
My coilovers will work with the 5 lug swap? lmfao I'm so dumb....
beanhead
Sep 24, 2015 12:04 PM
