Fuel Delivery Problems
7thgens official a$$hole
Well im having some fuel issues. My car is not getitng fuel to the injectors. It will start run for about 15 seconds then rough idol real hard and low at like 400rpm and die. Then other times it will start up just fine. and then other times it will not start at all. I have removed my fuel pump and tested it and it works fine. I have checked the 2 relays under the dash behind the glove box and they both work. I have only threw an actual code once and it was P065 i think im not excatly sure if thats the numebr because it was like 3 days ago when i checked it and frogot to write it down. but afer clearing my ecu the code goes away but the problem consists. I know that it is not a grounding out problem becasue i checked for that it is a problem with the positive end of the system. and i am getitng fuel pressure because when i pulled my fuel pump when it wouldn't start it shot out a decent amount of fuel from the line. if i didn't have any pressue this would not have happened. So, can anybody please help?
Oh yeah i have the hynes manual and it dosen't give me the code numbers so if anybody has that or can direct me to what the codes mean i will rep for it and it would be very appreciated.
But see how much pressure you have when you first turn the key to the on position. Should have around 40-47 PSI. If you have anything less, then check or replace the fuel pressure regulator and fuel filter and retest. If you have no pressure, most likely the pump has failed.
What you can also do, disconnect the line at the rail and turn the car to the on position, if fuel comes out there, then you are getting fuel to the rail. Also hook up a gauge set and run the car and watch the pressure. If it dies out and the car dies, I would suspect the fuel pump.
As for the code, I am not sure, I would need all 4 numbers.
basic codes
http://www.obd-codes.com/trouble_codes/index.php
yes i have fuel at my rail, and i do have fuel goinf through the pump, how di icheck the pressure? connect a guage to the fuel rail?
I'm having a similar problem, you might want to check this post: http://www.7thgencivic.com/forums/sh....php?p=3245648
CarStuff
Dec 6, 2020 12:52 PM
juror
May 26, 2015 06:35 PM
mrcell24
May 19, 2015 10:02 AM
dooner24
Apr 14, 2015 07:51 PM
