Help......pcv Valve - Check Engine Light
I Have A 2001 Honda Civic Lx, 1.7 Sedan
Should The Check Engine Light Come On Due To A Bad Pcv Valve.
If It Does Not, Could A Scan Diagnose A Bad Valve.
Thanks For Any Response
any auto parts chain should be able to hook you up for free and it will tell you exactly what sensor is causing the CEL
Our cars do use PCV valves. There are 2 OBD 2 codes associated with the PCV system too. Here:
http://www.hondaautomotiveparts.com/...=BREATHER+TUBE
number 4 in the picture is the PCV valve. Every car uses sometime of PCV system.
Originally Posted by jackburton
Never trust a dealer.
ANY TYPE OF DEALER!
ANY TYPE OF DEALER!
Originally Posted by gearbox
well alot of people have diyed it. and it does gt clogged. I don't see how it would be different from any other car fuel filter.
Ours is inside the fuel tank attatched to the fuel pump. you have to disassemble it from the pump and replace. Plus the electrical connection for the pump is on the filter. Plus it looks way different.
Xuhme
21
Aug 7, 2023 03:40 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
