IIM: Coilover Dampers Galore!!! EP3 ES1 applications
the best pricing for your suspension needs!!!!
Please pm or call 1-866-238-1947 for pricing!!
Monday-Saturday 11am-7pm pacific standard time
Megan Racing Coilover Damper Kits offer 32 Levels of damping force adjustment, full-height adjustment, and are matched with front and rear Pillow Ball upper mounts for camber correction.
Springs are made of SAE-9254 Steel, and are tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, spring durability was highly improved.
You will own full control of your vehicle reguardless if you are driving on a normal street, up to a mountain region, country road or formal race track.
Features:
- Spring Rates: 8kg Front and 10kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cyliner Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Limited Time Offer:
Only on ES1 and EP3 applications
Special Pricing for 7th Gen Civic Users.....
ES1 and EP3 applications and much much MORE!!
The RS coilover system is a 36 way damper and rebound adjustable full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts (compare to the TEIN FLEX!!!). Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
To top it all, these are available with custom spring rates!
Also, these coilovers come with a 1 year warranty against manufacturer defects!
Features:
- Aluminum Brackets
Limited Time Offer:
2k1civic.com O. G.
I have the Older D2 racing coilovers.
1. Are you SUREEE the application for ES1 (EM2 coupe) civics have the 3 locking perch design (independant height adjustment)??
2. Do you have or sell replacement rubber peices for the D2 coilovers? I need new rubber peices that go on the ends of the springs so the it eliminates Metal to Metal noises.
Yes, it's an Acura EL
Originally Posted by Yoyoio
i thot EP3, EM2 and EL shares the same suspension ?
what's the height adjustment on these? 3in?
p.s. the EL chassis code is ES, just like the Civic sedans.
wait wait wait hold the phone! 850 shipped?! ends today? like tonight at 12? i need some time to think about this
still have a few sets left.... 850 usd shipped to anywhere in the states...... great deal for the megan racing dampers!!!
I'll prolongue this deal until wednesday or until they are all gone... thx
beanhead
Sep 24, 2015 12:04 PM
Reppin Stage 7
