Best Place to Jack up front of car...
and to put 2 jack stands in front...what would be the strongest point from the front of the car, cause i dont want to wiggle on the sides putting each side up...
and for those of you with 5mt, did you put something like stoppers on your rear wheels just in case?
Try that the ridge there runs from front to back. It has to be strong enough to support the car when it's put on racks. Just take it easy and you won't bend anything.
Do one side at a time.
you jack at the jack points and use the ridge along the side of the car. It should not bend, except at the edges near the wheels.
Front of car Rear of car
Wheel - jack - jack stand jack stand - jack - wheel
There's a center jack point in the front of the car. Get under the car and you'll see an arrow on the plastic that points directly at it. It's right in the middle, maybe 1.5 in by 3 in. Jack from there, put the stands under the jack points that robbclark documented, and drop the jack.
What do you know... I just went out and checked and there is a center jack point.
can i jack the back up where the tow thing is? my car is so low and with my sideskirts on i cant jack the car up on the sides at all cuz there so low and theres no place to jack them up, even if i ride up on boards.
IOW, they're made to be pulled on and not pushed on.
There has to be someone here that can help you get around that.
I always jack up the back as described HERE.
Originally Posted by bobsagator
It's strange then how Honda specifies the tow hook as the rear jack point...
Yes! That is a much better way to jack up the rear!
Also, if Honda does specify the rear tow hook as a jack point then it must be good. They know the shear values the hook will recieve when put into compression like that.
I would still rather do it they way your illustration showed. That's a reall beefy area with nothing to worry about.
ok
1st off, use the OEM jack to get the car high enough to jack up the car with the real jack.
Secondly, you CAN use the tow hook as a jaking point, however, if you have a little jack, then they usually DO NOT go high enough to put stands underneath.
I use the point in the front, works fine. I use th ehook in the rear, works fine. Ihave to use the oem jack to get the car up high enough for the real jack though. My car/IC is too low. Than pop the jackstands under there, and drop the car slowly.
Originally Posted by MiamiUgen7
just an fyi, dont do it on the radiator support, that bends :-/
Originally Posted by robbclark1
I guess you speak from experience...sucks for you...:-)
at least Ive never attempted that. I use the jack point.
lilrob1213
37
Jun 29, 2015 06:45 PM
GH04si
Apr 15, 2015 08:13 PM
