lighting problem
lighting problem
my gages and rears lights are out, at first i was just gonna replace them but when i turn on m alarm my lights blinked cuz when i turn alarm on lights blinks 1 and turn off it blinks twice, so as i turned them on it blinks imm like WTH, i check the wiring and fuse box but nothing is wrong, some1 help me b4 the cops do plzzzzzzz.
ok now i hear a ticking noise in the fuse box in the hood *pic posted* now im getting scared, can some1 help me. I circles the fuse relay where the noise is coming from and i tested it is not the fuse. sorry if circle messed up im on laptop
well pull ou the relay that you circles and test it. Apply 12 volts to pins 3 and 4, and there should be continuity between pins 1 and 2. there should be no continuity between 1 and 2 with power removed from 3 and 4.
well i dun think i hear a click but ill try to listen for it. yo zen_master well mines is diffrent it wont turn on even if car is on or not and how would youu know if the fuse is blown?
yea i hear clicking, which relay is it the map dosent say and where can i get a replacement (if map says i cant read it its confusing) im not a real big electrical guy =D
The taillight relay is the one closest to the center and closest to the fuses (on the under dash box)
What year is the car and is it a coupe or sedan ??
You would need to test the relay as mentioned or check for voltage present from the switching side of it.
Do you have access to a VOM ? (multimeter) or a 12 Volt test lamp ?
The constant 12 Volt input to the relay is on the white/green wire. (should have 12 Volts at all times)
The switched voltage out to the lamps is a red/yellow wire (should have voltage when the parking lights or headlights are on)
PM with E-Mail and I will send you the info I have, I will try to stop by the library today and print out for the 01, but this info should be correct.
EDIT: I have the schematic for the 01 wiring if you need it PM
wait a minute, can you explain it again?
you blew #2 and #5, that's exactly the same as mine..........
what did you to to fix? i don't understand what u fixed..
in my problem........if i replace #2 and #5, my dash light indicators turned on....and i can't start my car
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
