Vacuum hoses?
Old Jul 21, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Vacuum hoses?
Hi guys,
When you refer as "check fo vacuum leaks", what lines/hoses do you need to check?
Any specific ones?
Charge pipes?
One's that altered while installing turbo?
Old Jul 21, 2005
turboengnr's Avatar
DONT PANIC
all of them. every line in the car.
charge pipes will not create a vaccum leak. But they should be tight anyway.
Old Jul 22, 2005
civic01vtec's Avatar
^^^ yeah, there aren't too many lines to check.....so check them all
If you find that a pipe keeps blowing off.....trying using a touch of hairspray.
Old Jul 22, 2005
I checked hoses that I've altered, changed some of them. Got a little better.
Will vacuum leak cause boost spikes?
Old Jul 23, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
vacuum leak can cause a crapload of probs. stalling, misfires, other crap like that. bad accleration too.
Old Jul 23, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
Whenever I have a Vac. leak, my idle goes crazy.
Old Jul 23, 2005
My Idle is very steady now, rolls at aboy 1000 rpm. Funny, but somestimes after a run it may go upto 1500 RPM's or so and stay there for a while and then drop back to 1000. Proly not vacuum then.
Any ideas?
Old Jul 23, 2005
sometimes resetting the ecu will fix idle problems. I thought I had a vacuum leak but turned out the computer just needed a good reset.
Old Jul 23, 2005
That's what I'm going to do after work. Late eve yesterday I unplugged the battery, so I will hook it today and let it idle for 10 min or so...
My current vac at idle sits at about -20, what I hear is the norm...
So, now I think my vacuum lines OK.
My problem now - is I get waaay to much psi, like at least 10 at about 4000 rpm's.
cferry7
Oct 3, 2015 04:33 PM
Hutch1051
Sep 29, 2015 09:20 AM
Sep 27, 2015 11:33 AM
thaler4cuse
Sep 7, 2015 08:25 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
