Vacuum hoses?
Vacuum hoses?
Hi guys,
When you refer as "check fo vacuum leaks", what lines/hoses do you need to check?
Any specific ones?
Charge pipes?
One's that altered while installing turbo?
Any specific ones?
Charge pipes?
^^^ yeah, there aren't too many lines to check.....so check them all
If you find that a pipe keeps blowing off.....trying using a touch of hairspray.
My Idle is very steady now, rolls at aboy 1000 rpm. Funny, but somestimes after a run it may go upto 1500 RPM's or so and stay there for a while and then drop back to 1000. Proly not vacuum then.
Any ideas?
Any ideas?
sometimes resetting the ecu will fix idle problems. I thought I had a vacuum leak but turned out the computer just needed a good reset.
My current vac at idle sits at about -20, what I hear is the norm...
So, now I think my vacuum lines OK.
My problem now - is I get waaay to much psi, like at least 10 at about 4000 rpm's.
Hutch1051
Sep 29, 2015 09:20 AM
Sep 27, 2015 11:33 AM
thaler4cuse
Sep 7, 2015 08:25 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
