2005 EX front brakes make click noise when wet
Does anyone know if it is normal for my front brakes (I believe I only feel it in the right side) to click a split second after coming to a stop? I will feel the click on the brake pedal. This only happens when it's raining or I just finished washing the wheels.
After driving around for like a block and using the brakes, the click stops and there is no more noise form the brakes.
The brakes do not make the click noise when it's a dry day.
Is this caused by the ABS or the water on the brakes causing it to slip because it goes away when driving and utilizing the brake?
I have an LX w/out ABS that does the same thing. Mine mainly does it after it's been sitting awhile (say overnight), or even when i go from reverse to drive. I've checked and tightened both calipers, but it still does it. I guess it's no big deal, just annoying.
i think i noe wat the problem is.. ur brakes pads are wearing oout... it is just about to hit the wear indicator.. it only happen for me when i reverse and then go foward.. the clicking is normal... it like a pre warning for your brakes....but it normal..u donthave to worry bout it...
Originally Posted by dru106
Its the pad shifting like when you goto drive to reverse!! No big deal, come on its a civic not a lexus
01 lx sedan
civicns
May 8, 2015 09:49 PM
Dorval Andre
May 1, 2015 09:37 AM
