My gas door won't open, It broke!
Old Jul 18, 2005
DMB's Avatar
DMB
DMB is an unknown quantity at this point
The switch to pop the gas door from the inside doesn't work..... So I had to have some towing company guy un-hook/split the wire from inside the trunk where it's continiously open now.
How much do you think it will cost to have that new wire spring replaced on the left side of the car?
$150?
Old Jul 18, 2005
CiViCPrAnInG2k1's Avatar
i had the some problem with the gas door too when i bought the car. i brought it to the dealer and they just put in a spring. but in my case, it wasn't working in the first place. is yours working before then broke?
Old Jul 18, 2005
DMB's Avatar
DMB
I bought it used last year. I think the warrenty ran out. (pretty sure). It just stopped opening like 2 weeks ago. But it got to the point where i had to fill my gas tank, and couldn't open the door, so had to resort to having it permantly opened....... But I need the spring FIXED. How much?, or should I just have the used dealership do it for me?
Old Jul 19, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
the part costs about $40 cdn.
I got my body shop to put it in while they were doing some other work. Find a mechanic or bodyshop who wants to do it, DONT TAKE IT TO HONDA, they want like 1.5 hours of labour. The cable involves replacing the line from the gas /trunk release to the gas door and the trunk pop.
Old Aug 9, 2005
SIR_Grrl's Avatar
SIR_Grrl is an unknown quantity at this point
I had the same problem with my hatch... brought it into the dealer and they fixed it... put in a new spring as well... no charge.
Too bad they don't fix everything like that!
Old Aug 9, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
the spring is cheap. I believe the spring connect to the trunk and gas. Buying the spring/wire is only $26-30 (from Honda). Me and my friend did the job, pretty easy (~40mins).
You can also open the gas door from the trunk.
Old Aug 9, 2005
Jrfish007's Avatar
I know on older civic's there was a fuel door realse in the trunk too, might want to look into that. But the spring should be cheap, you can probably just call the dealer and ask for a quote over the phone, it will be more acurate than anyone here.
Old Aug 29, 2007
makrovi's Avatar
makrovi can only hope to improve
Re: My gas door won't open, It broke!
My door doesnt open anymore, when I went to look at the switch by the door, I saw the splitter thing is just plastic and it cracked. Anybody got a part number, or a site online to order this part?
Old Aug 29, 2007
CraigW's Avatar
If a 7th gen Civic maybe this --> http://www.fueldoorfix.com/
Old Aug 29, 2007
Rufus's Avatar
Depends on where it broke. The fuledoorfix is perfect if your scenario fits, but otherwise you need a new cable. I bought a new cable for about 26 bucks a month ago. It's been too hot in AZ to fix it so it sits in my office and I open the gas door from the trunk.
Old Aug 30, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
haha, my thoughts exactly! Mine just stopped working when I hit North Carolina and now that I'm in Georgia it's been way too hot to work on so I just avoid driving it and open it from the trunk when I have to.
Mine's weird though, I can reach into the trunk and pull the cable out from the door and the door will pop open. But then I can't close it because the spring keeps popping it open after I push it shut. But if I hold it closed with one hand and put the cable back in place with the other hand it stays. It just won't open with the lever by the seat.
Old Aug 30, 2007
tastyratz's Avatar
tastyratz is an unknown quantity at this point
anyone ever buy from the fueldoorfix.com website? My girlfriend has the same problem. She has an 01 and the cable broke. Guess what we replaced that same cable for the same reason 6 months to a year ago. This is BS and it shouldn't be an annual fix!
Old Aug 30, 2007
makrovi's Avatar
Placed an order for one today. I don't remember where it broke, but looks like on the cable, that is the only place that can break since that is where they use plastic. STOOOPID HONDA. THe other end is metal attached to a thick plastic sleeved cable. I'll keep you posted when it comes.
Old Sep 1, 2007
DeX's Avatar
DeX
Canadian, Eh!
So is that what breaks? The cable? I have to rerun a new one all the way through the car?
Old Sep 1, 2007
kryngle's Avatar
kryngle is an unknown quantity at this point
This is the second time mine has cracked. The first time it was still under warranty and now I have been runnin my car like thos for months. All I do is go in my trunk and release it. Mine is a 2001 EL so I guess its an issue Honda needs to take a look at.
Old Sep 1, 2007
DeX's Avatar
DeX
Canadian, Eh!
Can I transfer my warranty from a Canadian dealership to one in the USA?
Old Sep 1, 2007
Rufus's Avatar
It breaks at the handle but it can break in a few ways.
Old May 12, 2013
yrch69's Avatar
yrch69 is an unknown quantity at this point
Fixing the Honda Civic fuel door problem for under $3.00
This only works if your problem is caused by the broken plastic connector (which is the most common cause). This was done on a 2004 Civic Sedan LX. The process should be very similar for other models, but may vary slightly based on door jambs and other design variations.
To see the pictures, view the original post:
https://www.civicforums.com/forums/1...ml#post4640389
---- Tools you'll need See Pic #1
- 10mm socket (if you're using a ratchet, you may need an extender, as the bolt is about 1" recessed. see pic #5)
- phillips head screwdriver
- pocket knife or other blade
- at least 2-3 feet of wire (under $3.00 at any hardware store, should be with the picture hanging supplies. I found 28 gauge to be the optimal size, but anything from 24-32 gauge should work)
---- Phase 1: Getting to the cable
-- Step 1: Remove the single screw by the Fuel Door Lever See pic #2
Open your driver door. By the Fuel Door Lever, there should be a key hole visible. Using a flathead screwdriver, a knife, or a key, pry the small plastic cover off the top. Using a phillips head screwdriver, remove the screw that was underneath it.
-- Step 2: Remove the Hood Release Lever panel cover See pic #3
We need to remove the plastic door jamb cover to get at the fuel door mechanism. Before we can do that, we need to move two other plastic jamb covers, starting with the one in front of it, near the Hood Release Lever. The easiest way to get it off is to start from the left (outside edge), pull it back and push it to the right, over the door jamb. Then reach inside under the dashboard, grab the back right edge, and pull back toward you a little, then pull it to the right, toward the passenger side. Don't be afraid to wiggle and apply a good deal of force, you won't break it.
-- Step 3: Loosen the Vertical Door Jamb Cover
The next step is loosening the Vertical Door Jamb Cover between the front and rear door. Open the driver side rear door (this will relieve pressure on the vertical jamb cover and make your job easier). From the outside of the Driver door, pull the cover back and push toward the inside of the car. It should pop loose pretty easily. Just lift it up about 4-6 inches, then close the rear door to hold it there so it won't be in your way for the next parts.
-- Step 4: Remove the Fuel/Trunk Lever Cover
This one is held in place by about 5-6 snap-in buttons (3 on the outside, 2 or 3 on the inside). Just pry it off slowly, a little at a time. Once it's loose, it will lift up easily, but it may feel like it's connected in the back under the driver seat. There's another button back there that gets caught on wiring and makes it hard to lift out. Wiggle it, or go in through the rear door to get a better angle and release it in the back. Moving the driver seat forward/backward can help, too.
-- Step 5: Getting the cable loose See pic #5
After you have the panels off, loosen the bolt just a little, but don't remove it (10mm socket). Pull the whole Fuel/Trunk mechanism backward about half an inch, then lift it out. Turn it over, and you should see that the white plastic piece connected to the black cable has broken. If the white plastic piece is intact and still connected to the black cable, then your problem is somewhere else (good luck). If the white plastic piece is broken, pull/pry it out of the metal housing, then remove the end of the cable from the bottom of the Fuel/Trunk lever (it slides right out once the white plastic connecter is released).
---- Phase 2: Repairing the damaged connector
-- Step 1: Give yourself more cable to work with (optional See Pic #1)
To get a better angle to work on the cable, I recommend pulling it backward under the driver seat, giving you another 6 inches or so. There's a metal support under the carpet by the driver seat. Just lift the carpet, find the cable 8 inches or so back from the Fuel/Trunk Release, and pull it out from behind the support, then lift it up. It's easy to put back later. This will just give you more flexibility while working.
-- Step 2: Cut notches in the bottom rung
For this fix to work, the #1 priority is to wrap tightly and maintain tension on the wire wrapping. To help keep everything tight, I cut two notches in the bottom-most rung of the white connector. This allows the wire to lay flat against the side, and keeps it from moving around, which will reduce flexing/stretching. Using a pocket knife or any blade, slowly and carefully carve two notches on opposite sides. I cut mine all the way down to the center body of the connector to make sure the wires would stay snug.
-- Step 3: Wrap the wire (lots of text below, but it's pretty easy really) See pic #6
Starting with about 2-3 feet of wire, find the center of the wire and put it in the bottom rung of the connector, leaving equal lengths of wire on both sides. Pull the Left and Right sides around to the front and continue around to the back, so each side has wrapped around 360 degrees. Pull them VERY VERY TIGHT, and twist them once around each other, switching hands and returning the wires in the opposite direction while making sure to keep tension on the wires. This will "lock" the wire and help keep the tension. Keep the wires very tight and wrap back around to the front. At this point, you should begin twisting them around each other, sort of like a braid, keeping tension to ensure they are wrapped tightly and there is no slack. KEEP THE BRAID VERY TIGHT to keep tension and not allow any slack. The "braid" should be right over one of the two notches, and should lay down along the side of the plastic connector. Keep braiding until you're RIGHT AT, or JUST UNDER the metal piece on the black cable, where it goes from metal to black plastic. Then, pull it very very tight, and wrap each end of the wire around the black cable below the metal part. Wrap each end around once or twice. Pull very tight, and twist the wires around each other, switching hands and reversing, to "lock" the tension. Do this a few more times (wrap once or twice, twist them, then switch hands and reverse). After 3 or 4 reversals, bring both ends of wire around to the side of the empty notch (opposite of the first braid), and begin braiding back up toward the white connecter. KEEP THE BRAID VERY TIGHT to keep tension and ensure there's no slack. Keep braiding until you're RIGHT AT, or JUST UNDER the bottom rung of the white connector, then begin the same process as before. Wrap once or twice around, then twist, switch hands and reverse direction. Do this 2 or 3 times to "lock" the tension in the wire, then braid the remaining ends together half a dozen times, cut off the extra, and push the braided end into the bottom rung so it's out of the way.
You should now have something that looks like Pic #6, and hopefully is extremely tight and and the two pieces of cable are connected and don't move around much (or at all).
---- Phase 3: Reassembly
Feed the cable back under the metal bar and the carpet. Attach the cable to the Fuel/Trunk lever. Put the mechanism back in place, and tighten the bolt with your 10mm socket. Test the Lever to make sure the trunk and fuel door are both opening easily.
Now just put everything back together by reversing the directions in Phase 1. The only part I found annoying was the plastic jamb cover over the Fuel/Trunk Lever. If it's not on just right, the lever will kinda get stuck on the plastic jamb cover when you try to open the trunk. So, after you reattach the Fuel/Trunk cover, but BEFORE you reattach the other two jamb covers, test the Lever to make sure the trunk and gas door open easily. If all looks good, pop the other covers back in place, make sure everything is snapped in and secure, then clean up your work place and give yourself a pat on the back.
-- NOTES:
Pic #4 was removed. Apparently there's a limit of 5 pictures on uploads.
As you can see in Pic #6, my 2nd notch isn't deep enough, and my braiding is a little loose. I took this picture after testing my "fix" a few times, and the test runs seem to have loosened the wires a little. All the more reason to keep every micron of slack out of the wire. The tighter your wrapping, the longer it's going to last. Judging by the look of mine after half a dozen Fuel Door openings, I expect that I'll need to re-wrap mine tighter if I want it to last more than a few months. We'll see, though!
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MamaBear2015
May 18, 2015 07:37 PM
maaronia
May 14, 2015 10:46 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
