Passenger side higher than drives side...
Old Jul 17, 2005
tavdawg's Avatar
tavdawg is an unknown quantity at this point
I just went out to measure how much I want to drop the civic. Well when i measured the passenger side it was a 1/4 inch higher in both front and back than the drivers side. Why would this be... no speakers, no junk in the car... 1/4 tank of gas if that even matters. I just dont get why this would be. So my question is once I drop it about 1.5 inches do you think its still going to be unlevel? Probably going with the tokic hp and H&R sport springs.
Old Jul 17, 2005
scatman's Avatar
Still in the game...
it may be becuase most of the time a car's weight isnt perfectly distributed, its nothing to worry about.
Old Jul 17, 2005
robbclark1's Avatar
Retired suspension supermod.
It's normal and you really can't tell a 1/4 of inch. If you really need it to be completely even get full coilovers and have a fun time adjusting them.
Old Jul 18, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
my car is like that too. i have the tein s-tech with koni yellows. i have just learned to deal with it...
Old Jul 18, 2005
robbclark1's Avatar
It is from the distrubtion of the engine and because most of the time there is only 1 person in the car...you.
Old Jul 18, 2005
Monk33's Avatar
Monk33 is an unknown quantity at this point
Yep, this is exactly the problem. If you open your hood and look at the engine, you'll see that most of the bulk of the engine is sitting on the driver's side. (This is especially noticeable if you have installed an aftermarket intake and removed all the useless black plastic factory intake boxes). When you add your own weight to the equation (which also happens to be on the same side of the car) you can see why the driver's side will always be sitting a little lower. The only way to even things out is to install adjustable coilovers, (which I eventually did because of my perfectionist tendencies!), and keep adjusting them until you get it all even. Good luck!
Old Jul 18, 2005
tavdawg's Avatar
Thanks for your responses. I guess I will just have to live with it.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
pratik05
May 15, 2015 01:54 PM
crowtoo
May 11, 2015 06:50 PM
fordfocussucks
Nov 19, 2001 07:22 PM
