02 Civic - A/C Problem
Old Jul 16, 2005
legacy345's Avatar
legacy345 is an unknown quantity at this point
Question 02 Civic - A/C Problem
Hey everyone, new to the board and have a 02 Civic.
Been having problems with the A/C. Its not working and apparently its fully charged. If by passed then it works but if not it won't work unless we run it direct. Any one had this issue before??? and what could it possibly be??
please advise
Thanks everyone
Old Jul 16, 2005
streetglower's Avatar
What part are you bypassing? If it works after bypassing a certain part, then that part most likely failed.
Old Jul 16, 2005
legacy345's Avatar
Apparently my buddy by passed the cycle switch or somethin and the a/c compressor clicked in and worked but if not then it doesn't work....has anyone had a problem similar to this??
Old Jul 16, 2005
tacheon's Avatar
tacheon is on a distinguished road
please advise
Thanks everyone
How do you know it is fully charged? There is a low pressure cutoff switch which will prevent your a/c compressor from comming on if you are low on refrigerant. If you bypass this, you will force the compressor to run at the risk of damaging the compressor since the refrigerant carries the lubricant for the compressor as well. You can also look into the evaporator temperature sensor. If this is faulty, your a/c compressor won't come on either. Bypassing a faulty evaportator temperature sensor will make the compressor come on if everything else is working properly.
Old Jul 16, 2005
halpierce's Avatar
halpierce is an unknown quantity at this point
More than likely your switch is bad, is it the low freon switch that he is bypassing, If it is then it will be the switch bad.
Old Jul 16, 2005
tacheon's Avatar
These cars use R134a. Freon is so 90's... lol.
Old Jul 16, 2005
legacy345's Avatar
switch/low refrigerant
I took it into the mechanic and he had said that the refrigerant is full but he order some switch or sensor or somethin that was under the dash but he put it in and it still the same thing. He can't seem to figure it out just yet so I figure i'd cut some time and ask some experts on here.
Thanks guys for the input.
Old Jul 16, 2005
sounds like you need to go to a better mechanic.
Old Jul 16, 2005
legacy345's Avatar
thanks streetglower
He's been pretty good so far but for some reason this time around he has been uncappable of taking care of this problem
tattedlariat
Apr 20, 2015 09:26 PM
paulnguyen
Apr 20, 2015 01:33 PM
dooner24
Apr 14, 2015 07:51 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
2Hondaz
Nov 8, 2001 11:00 AM
