Acceleration is DEAD!!
I got a 03 ex coupe with a 5 speed. For the last month or so the acceleration has been horrible. And there isnt any vtec anymore. It doesn't kick in at all. I was wondering if anyone knows what the problem might be or if anyones experienceds this? Id rather here from someone on here rather than take it to the shop. lemme know something. thanks
how many miles on the motor oil? if your past 5000... change it immediately
is the clutch worn? if its slipping, that could be an problem as well.
could even be the motor itself...theres so many possiblities, gonna need to provide more detailed info
true on never having the vtec, but the acceleration is noticably worse now that i don't have it anymore. the clutch isnt too warn, 33k miles, oil changed frequently, air filter changed, plugs are good, car never overheats, oh... not to mention, i was in an accident, the entire right front end of the car was smashed in (including intake, headlight, suspension, all that good stuff up there was pushed back about 2-5 inches). Those houses just come outta no where! Everything was "fixed" until i put about another 5k miles on it and now it runs like crap. also, the engine its self makes a fast, light sputtering sound. i cant visually see any damage done to the motor so i have no idea where the problem might be. if this info doesnt help will honda charge to diagnose the problem or is it warranty? also since i was in an accident does that void my warranty, all the repair work was done by a certified body shop? thanks again.
I Hunt Goats, Rams, And Mustangs.
Try disconeting the vtec syloniod see if you feel any difference in the way the engine runs. Could just be that its gone bad, or thats ran off oil pressure and its not getting fed enough, may have some sludge or something built up in the oil pan.
Drunken Master-7thgen Ninja
it don't matter if you got hit, its still under warranty. and how do you know vtec didn't kick in? how old are your plugs? your oil? your air filter? and btw it could be a vacuum leak or something along those lines. go to the dealership, it should be fine.
alright i called honda and the guy said its still under warranty even with the accident. supposed to drop it off wednesday morning. i have one more question, anyone know where i can get a service manual for cheaper than $100?
your car is still really new with 33k miles but when you get up there. Add seafoam to the engine and gas tank...
That will clean out the carbon deposites
Bruce2
Sep 27, 2015 08:45 PM
Skunkone
Sep 24, 2015 04:38 PM
dantheman42
Sep 4, 2015 01:10 PM
