upgrading speakers
Old Jul 8, 2005
Derrik's Avatar
Derrik is an unknown quantity at this point
upgrading speakers
Hey im planning on upgrading my stocks finally... im thinking of alpine type r's or type s. Im looking for a mix of sq and spl i want clean sound but good thump if that makes any sense lol. well i know im gonna need to make some spacers ect.. but im just owndering if i should get coxials or components... i dont really know the diffrence. another.. should i upgrade fronts and rears or just fronts. Hopefully upgradeing the speakers will be a big improvement, thanks
Old Jul 9, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
get the components for the front. Also upgrade front and rear if you want a good mix.
SQ - get rid of the rear
SPL - Use the rear for 'fill' (and subs for the actual Sound Pressure)
Alpine Type R's are low-to- 'middle of the line' for most people. Personally, I'm glad I spent the extra $$$ for my JL Audio XR series speakers. It all really boils down to your budget and type of music you listen to.
Old Jul 11, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i thought JL's were "low to middle of the line" also?
derrik - are you planning to add a sub/subs?
Old Jul 11, 2005
MegaHurtz's Avatar
if you are looking for ANY spl at all you will wnat to look at a sub (or pair of subs) in addition to speakers. my personal recommendation is to run a high ended set of front speakers as opposed to buying front and rear that are only middle of the road, and getting a sub (or pair, like I mentioned before)
if you only want speakers and no subs, then it goes without saying that you will not be doing any spl
Old Jul 11, 2005
LayinLo's Avatar
constructive criticism, I hope............
I listened to both the Diamond Audio D6 series and the XR line of JL. I guarantee that YOU couldn't tell the difference between the two.
I would have put the Diamonds in, but ran into space issues, then I heard the JL's. No complaints here.
Old Jul 11, 2005
Derrik's Avatar
im running subs.. a 12 inch alpine type r with a alpine 600w rms monoblock amp....
Old Jul 11, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
Nice set-up Derik I have the same set-up, a type r 500 rms and a mrd-m605 600 rms.
Old Jul 11, 2005
Derrik's Avatar
hells yea i purchased a set of sps-171a's gonna get them put in sometime and probably gonna switch out my age old panasonic deck for a iva-d310 or somethin.
Old Jul 11, 2005
whatever you get, spend some time and do the install correctly. I have bottom of the barrel infinity reference 6.5 inch all around and they sound amazing, prolly very similar to the expensive speakers. Put a layer of dynamat on the door metal, make sure the spacers that the speaker sits on is sealed up and it wouldn't hurt to stick a dynxorb pad behind the speaker on the outer door skin to prevent back-wave distortion. you can get these from www.carmedia1.com
Old Jul 11, 2005
zachgeyer's Avatar
components i got mb qarts they rock!
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Cam Diaz
Sep 29, 2015 07:17 PM
Gsxtacy
Sep 12, 2015 01:09 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
