Weird noise coming from my AC.
Old Jul 7, 2005
mrb420's Avatar
mrb420 is an unknown quantity at this point
I have a wierd noise that comes from my 01 civic. It seems to occur only when the AC is turned on (or the fan too.) It sounds like a slide whistle.
It seems to come from somewhere inside the passenger side dashboard.
Does anyone have any idea what it could be?
Also, anyone know where to find the best price for a new pollen\dust filter. The dealer out here charges about 21 bucks for one filter. That's not too bad, but I'm just wonderin'
Old Jul 7, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Is it only when the ac is on?
Old Jul 7, 2005
mrb420's Avatar
Yes. And it doesn't always happen. It will be fine and then just start making the slide whistle noise. When I tuurn the fan control to off, it stops. I am assuming it is the AC since it is like 100 degrees out here and I am not runnign just the fan or the heater. Maybe I need to park and open the windows and just run the fan...
Old Jul 7, 2005
Try that and see what happens.. let me know
Old Jul 7, 2005
cwick187's Avatar
cwick187 is an unknown quantity at this point
I have that same noise when my AC is on...I think it has something to do with the compressor. Im going to take it to my mechanic and let him look at it
Old Jul 7, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
yea..... i have the same problem also..... well not lately but about a month ago and before that.... all i did was turn the AC all the way up until the noise go away then i turn it back down.
Old Jul 13, 2005
jmontoya's Avatar
jmontoya is an unknown quantity at this point
same problem
hey guys,
I have the same problem, mine was after I replaced the condenser on my 01 Civic and initially the noise was not everytime but now is all the time, if I turn off the AC it goes away but I can tell it is either a fan somewhere or the compressor.
please keep us updated with your findings
JM
Houston
Old Jul 13, 2005
well.... mines juss turned back on the other day and it was getting annoying, so i just left the AC on and redlined it on 1st and 2nd gear and then i heard a loud squeak noise under the hood and then it went back to normal. so then the AC stop making that noise. i wouldnt suggest anyone to do what i did because i wouldnt want anyone compressor to mess up or anything... just wanted to share what i did...
Old Jul 13, 2005
mrb420's Avatar
The noise on mine seems to come from inside the dash behind the glove box. It only happens some of the time.
Old Jul 13, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
could always turn up your music
Old Jul 13, 2005
yea.... thats where i heard mines coming from too.
Old Jul 13, 2005
skipbarber's Avatar
mine does it too, it's done it since new. doesnt bother me.
Old Jul 13, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
when mine did it i looked around and found it. there's a sensor in the air ducts under the driver side, down by the fuse/relat box it just twists in and mine got untwisted, if i had a digi cam i'd take a pic, u have to be down on the driver side floow to see it, if ur face is about 8 inches away from the gas pedal and u look to your upper right you'll see it if my memory serves me, the end is white
Matt.
Old Jul 13, 2005
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
i've been getting kind of a high-pitched whistling noise when my A/C is on too, especially when the condenser clicks on and off - since I bought the car actually. I've been getting used to it though...
Old Jul 21, 2005
stock's Avatar
stock is on a distinguished road
Matt.
I heard the same whistle noise with A/C on when the blower fan was on both upper and lower vents and on recirculation mode. It comes and goes away. I haven't heard it for a while.
I find the A/C colder in recirculation mode than fresh air mode. Does your A/C seem to be cold for a while then warm then cold again. It's like the A/C is turning off and on.
I found the white sensor under the dash /centre console. Is this thing making the whistling noise? If so how do you fix it?
Old Jul 25, 2005
mrb420's Avatar
I just took my car in for the timing belt replacent and I asked the mechanic about the noise. He said it's no problem. It is actually a value that releases the pressure that builds up when your condensor converts the Freon from a gas to a liquid or when the liquid turns into a gas later in the system. Anyway, he said sometimes the valve makes noise and sometimes it doesn't. No big deal.
Old Jul 25, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
i wass getting a belt noise whenever i drove so i took it in to honda. also had a knocking noise when i had the A/C on. they said its the A/C compressor and the a/c clutch is loose from wear making that knocking noise. they're fixing it wednesday under the honda care plan
they also noticed something wrong with my 02 sensor. they guy called and hes like "um i think theres a problem with your 02 sensor - you don't have one" hahaha i was like yeah i replaced my downpipe and he's all "ooooooh that makes sense now" haha he didn't know what the hell he was talking about, just was reading what the tech wrote on the workorder.
Old Jul 25, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Issues & Problems forum
Old Nov 22, 2005
CapYoda's Avatar
Escaped Convict
so anyone ever figured this out? (there seems to be numerous thread on it, although some are probably different noises)
I have the same problem... only when AC is on, high pitch whistle noise. sounds like when a cop turns on his siren for a wee bit.
it wasnt a big deal before, but now its getting a bit more frequent, so I finally got off my lazy butt to check it out.
Old Nov 22, 2005
...and the results of getting off your lazy a$$?.... haha..
i still get the knocking noise...well its more like a rattle. i found out it does continue while the car is moving..you just cant hear it cuz of the engine noise. but..if im at a stop and it comes on...i push the clutch pedal in and it goes away
Old Nov 22, 2005
pon55's Avatar
Loose belt!
Old Nov 23, 2005
CapYoda's Avatar
Escaped Convict
oh i meant checking it out as in searching about it. lol..
I'mma check the belt then. not sure if its that though...
Old Nov 25, 2005
stock's Avatar
So is the whistling noise normal or is it a loose belt? It doesn't sound like a loose belt though... It sounds like a whistle...
Old Nov 27, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
its the clutch pully on the compressor. Just spray some wd-40 on it, you'll be good to go. happens to mine all the time, just keep it greased.
Old Dec 15, 2005
stock's Avatar
So where is the clutch pulley located? Won't WD-40 remove the existing grease?
civicns
May 8, 2015 09:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
SSMatey
Apr 13, 2015 06:09 PM
Sparty
Nov 15, 2001 04:55 PM
eX2ooo
Oct 5, 2001 12:19 AM
