just bought tein ss's
Old Jun 30, 2005
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
hey,
i just bought a set of tein ss's i was wondering if there is anything i should do or i should buy for the car to go along with the coilovers before i install?
forexample shorter bumpstops? new bushings? etc? i dunno?
thanks,
Patrick
Old Jun 30, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
camber kit
Old Jul 1, 2005
JCiv03's Avatar
Just a suggestion, but I've read taht you should use some "Anti-seize" lubricant on the threads so they don't get messed up.
Old Jul 1, 2005
robbclark1's Avatar
Retired suspension supermod.
Yes, use antiseize all over the threads and the rear camber kit. You should have a camber kit. Also, you might need an upper mount bearing if you have an 02+
Old Jul 1, 2005
sorry about these questions I know they have probably been answered before but when I get a chance to go online its not for a long time and most of the time its really slow it takes forever to search (im in Iraq right now)
I have an 02 Ex coupe... will I need that upper bearing?
Old Jul 1, 2005
hmm BUMP!
Old Jul 1, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
I reccommend cutting the plastic dust covers in the rear, mine bottomed out and ended up rubbed the threads and causing a horrible sound. Save the time, and cut a couple inches off the dust covers that protect the shock rod....
Old Jul 1, 2005
dj02's Avatar
yes you will need the 01 upper mount.
Old Jul 1, 2005
skipbarber's Avatar
really? i have an 02 and my SS's went on with no problems.
mistermenphis22
Apr 3, 2016 08:06 AM
califcamper
Jul 13, 2015 11:50 PM
cukaracha
Jun 7, 2015 03:32 PM
elitezdc5
May 26, 2015 05:46 PM
