just bought tein ss's
hey,
i just bought a set of tein ss's i was wondering if there is anything i should do or i should buy for the car to go along with the coilovers before i install?
forexample shorter bumpstops? new bushings? etc? i dunno?
thanks,
Patrick
thanks,
Patrick
Yes, use antiseize all over the threads and the rear camber kit. You should have a camber kit. Also, you might need an upper mount bearing if you have an 02+
sorry about these questions I know they have probably been answered before but when I get a chance to go online its not for a long time and most of the time its really slow it takes forever to search (im in Iraq right now)
I have an 02 Ex coupe... will I need that upper bearing?
I reccommend cutting the plastic dust covers in the rear, mine bottomed out and ended up rubbed the threads and causing a horrible sound. Save the time, and cut a couple inches off the dust covers that protect the shock rod....
yes you will need the 01 upper mount.
really? i have an 02 and my SS's went on with no problems.
mistermenphis22
Apr 3, 2016 08:06 AM
