HELP: Car Wont Start, rapid clicking noise
Old Jun 30, 2005
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Exclamation HELP: Car Wont Start, rapid clicking noise
Im stuck in a shopping plaza cuz my car wont start. If someone could help identify the problem that would be great. I will try to be as clear as possible with my description.
I put in the key and turn it, instead of starting I get a rapid and distinct clicking noise. The odometer flashes rapidly and my gauge needles all flutter quickly too. The dome light flashes quickly and the car does not start.
I do not know what the problem is but my voltmeter says i still have 11 left in my battery, which i thought was more than enough to start my car. Is the battery still my problem or could it be something else?
Please help!
Should I try to jump it?
Old Jun 30, 2005
Ellocodetroit's Avatar
The Declaration of Independence was written on marijuna paper
Ellocodetroit is a jewel in the roughEllocodetroit is a jewel in the roughEllocodetroit is a jewel in the rough
Starter maybe?
Old Jun 30, 2005
How many miles and what year?
Old Jun 30, 2005
Vinnie's Avatar
My car is a 2001 sedan ex. It has 34,XXX miles. I have half a tank of gas, so thats not the problem. My car has been sitting in the parking lot over night but the temperature is nice outside.
How do I know if its the starter that is causing the probleM?
Old Jun 30, 2005
That clicking IS the starter, so its prolly working fine. I would think the battery first, then maybe something like fuel delivery system. Spark, air, and fuel needed to start a car. You don't have one of those.
Old Jun 30, 2005
eharkins's Avatar
eharkins will become famous soon enougheharkins will become famous soon enough
the battery is dead. i've let mine die like 8 times and everytime it does that shakey needle and click thing. just jump it off and you'll be good.
Old Jun 30, 2005
scizod's Avatar
scizod is an unknown quantity at this point
had similar problem....
My civic died at a light once. Did the same thing as yours. I ended up frying the coil. It was very easy to replace and the part was not that expensive. Sounds like the only thing you can do is get it towed out of there and bring it to a trusting mech. Flip him $20 and ask him to diagnose it.
Old Jun 30, 2005
DaSilverCivic's Avatar
DaSilverCivic will become famous soon enough
it's the battery . . . your description is exactly what happened to me a few months back. got it jump started and worked fine. few days later happened again. jump started it and got a new battery.
Old Jun 30, 2005
scizod's Avatar
not battery....
Please help!
He put the volt meter up to ut and he got a good reading. Also, the lights would not flash if it was the battery.
Old Jun 30, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
yes it would, happened to me
Old Jun 30, 2005
wonderz's Avatar
wonderz is on a distinguished road
check to make sure all your wires (ie. ground wires, power wires, etc) are secured.
Old Jun 30, 2005
Vinnie's Avatar
Thank you everyone for your help. I replaced my stock battery with an optima yellow. Car started immediatley.
Tomorrow I will bring my car in to make sure that it wasnt my alternator that broke and simply wasnt charging the battery.
Again thank you for all your help!
Old Jul 1, 2005
The battery light should come on if there is a problem with the alternator. And that optima will bring you years of good starting and resistant to discharge cycles.
Old Jul 1, 2005
skipbarber's Avatar
11v is not a good reading. you need atleast 11.4v to start.
Old Jul 1, 2005
eye_see_you's Avatar
let the devil out
Its battery I promise you. I had the same thing happen after I did my HU install and was playing everything for awhile without he engine running. Also it could be the alternator or bad ground that caused it
tylerginevan
Apr 27, 2015 12:29 PM
Linda0818
Apr 23, 2015 11:30 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
SSMatey
Apr 13, 2015 06:09 PM
Boosted
Nov 7, 2001 09:41 AM
