Another Cold Air Intake Question
Old Jun 9, 2005
stepchild's Avatar
stepchild is an unknown quantity at this point
Is it necesary to remove the ground terminal from the battery before installing a CAI? If so why? Info would be appreciated. Thanks
Old Jun 9, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
I would say yes.. I dont know what the heck i touched, but i made sparks fly when i installed mine with out undoing the ground.
Old Jun 9, 2005
it's mainly so the ecu resets and accounts for the extra air flow.
Old Jun 9, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
You gotta do that? *shock* I didn't know that... Should I? Does this mean I'm running lean right now?
Old Jun 9, 2005
Hayz's Avatar
yep I always reset mine after adding any kind of engine work....
Old Jun 9, 2005
well the ecu does adapt after a tank of gas or so. It just takes a bit longer than if you straight out reset the fuel trims.
Old Jun 9, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
yea the most that will happen you'll get an engine light as I did for not removing it, but it goes away after the first tank of petro. At least mine did.
Old Jun 9, 2005
...ever grinning...
Well I'm about 3 tanks out so... I'm good then, right?
Old Jun 9, 2005
ya its mostly to set the idle rpms, which really doesn't come into play unless you get a new throttle body or something. Your car has already learned from whatever you added 3 tanks ago.
Old Jun 9, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
youre fine, but there was a member on here that installed an intake and didnt reset.... went out for a test run, came back, the header was glowing red....
Old Jun 10, 2005
...ever grinning...
Old Jun 10, 2005
thats a common problem with the lx anyway. header gets clogged up too easily and then overheats.
Old Jun 12, 2005
stepchild's Avatar
Thanks guys. I just now read replies on that but I didnt unhook the negative battery terminal. By the way, cold air intake is installed! Check out the DIY on AEM cold air intake and it tells you how to reset your e.c.u.
Old Jun 12, 2005
stepchild's Avatar
I did however have a problem when taking off the factory air intake enclosure(where the air filter is at)! 3 of the 6 bolts stripped out ,breaking the plastic casing the bolts thread into. But my friend who has owned and worked on some of the nicest automobiles (Supra, Peugot etc.) spotted a clamp around the throttle body, under the casing with the filter in it. He loosened the clamp and off came the box! I will have pics of the clamp and the stripped out bolts soon........and here are the pics
Name:	no bolt 1.bmp
ID:	55570   Click image for larger version
Name:	no bolt 2.bmp
ID:	55571   Click image for larger version
Name:	no bolt 3.bmp
ID:	55572   Click image for larger version
Old Jun 12, 2005
stepchild's Avatar
I just want to say thanks to everyone who replied I appreciate it!!!!
Old Jun 12, 2005
hmm... I never had that problem, although once, ran the car hard for a good 10-15 minutes and it stunk a bit.
ORskier
May 7, 2015 04:54 PM
colombianDXcivic
Bolt-on Engine Performance
Nov 25, 2001 09:38 PM
808specifxz
Nov 17, 2001 10:39 PM
Hobby2K
Nov 9, 2001 04:08 PM
SneakerPimp
Nov 4, 2001 01:12 PM
