taillight bolt broken-help!
Old Jun 9, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
intalling my new taillights i broke one of the stud bolts, they look exactly the same as the oem, is there anyway to take the studs out of the oem ones and put them in my aftermarket ones? and do you know any other options I have to attach this light. thanks
Old Jun 10, 2005
nothing huh?
Old Jun 10, 2005
R1Style's Avatar
Well if you look at your tails... can you actually take the stud out? If not you might be able to get away with only using the two studs.
If you can take them out... just swap it out from your factory tails and use those studs.
Old Jun 10, 2005
na i looked, and was trying to twist them out but they wernt budging, there is actually 4 total, it holds with three but it sticks out a little.
Old Jun 10, 2005
PennyKnotOff's Avatar
Which one broke?
Old Jun 11, 2005
the one furthest out, so the end sticks out a bit...
Old Jun 16, 2005
f- it a self tap will have to do...
Old Jun 16, 2005
zip ties and duct tape..
Old Jun 16, 2005
pon55's Avatar
You ain't working on my car!!!!!!!
Old Jun 17, 2005
AlienX's Avatar
AlienX will become famous soon enough
this is a little risky, but you can try to heat up the bolt and try to slide it out of the plastic, doing the same with the stock and just swapping. You can try to call up a machine shop and see if they can fix it, that would prob be your best bet and safest.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
