NA 14sec D17A2
Old Jun 7, 2005
kezay's Avatar
kezay is an unknown quantity at this point
NA 14sec D17A2
Aight fellow members here's the deal..... I got called out to race from another all motor civic. Here's my setup:
Full Tein SS suspension
Energy suspension Bushing kit (front and back)
Neuspeed upper strut bar
Crower stage 3 cam
Crower Titanium spring
Crower Titanium retainers
Crower stainless steel valves
Crower camgear
CP Forged high compression pistons (11.5:1 + .020 overbore)
Crower maxi lite rods
AEM pulley kit
Koyo aluminium racing radiator
B&M short shift kit
ACT Extreme pressure plate
ACT 6 puck copper disc
ACT Prolite flywheel
ARP headstuds
Is it possible to run low 14 to high 13 sec in the quarter mile using slicks???
The race is for $1000. (However it is all motor vs all motor, no turbo or nitrous but anything else is accepted)
Old Jun 7, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
what is the other guy's setup?
edit: impossible to tell without a dyno ... we don't know what the crower cams produce ...
you'd probably gain a lot more power if you were tuned ;P
Old Jun 7, 2005
kezay's Avatar
he has a mildly built B18C
I knoww I would gain alot if I tune properly but the only way i see it is with AEM EMS, but that kinda expensive for now.
But otherwise do you this that i can do this??
Old Jun 7, 2005
civicrider01's Avatar
civicrider01 is an unknown quantity at this point
What are you racing?
Old Jun 7, 2005
WhiteCastle's Avatar
Neuspeed upper strut bar get rid of this..Energy suspension Bushing kit (front and back) I would remove the bushings
I would also remove all the seats except one and loose the interior pannels. I would also run higer comp than 11:5:1 Im talking racing fuel. Or literlly just throw racing fuel in, it will actually help.
Than you should have a shot!
Old Jun 7, 2005
kezay's Avatar
an older model hatch civic
Old Jun 7, 2005
I would defently do everything I said than..
Also get rid of the spare tire while your at it if you havent already.
Get some light weight 14 inch rims as well
Old Jun 7, 2005
alberta_si's Avatar
alberta_si is an unknown quantity at this point
i dont no what hes got but b18's stock are faster... so take it from there depending on what hes got and in what car... but with what ive seen, i 'm not shure about running low 14... then gees i want to go that root, cuz i love all motor!!! good luck!!!
Old Jun 7, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
oh .............
I'd call off the bet.
Old Jun 7, 2005
Originally Posted by aznboysrfr
oh .............
that works too,
also you can get rid of your cat and run a straight pipe!. I would loose the air conditioning unit! umm lets see what else guys
honestly I would try with the reasonible stuff I listed
Old Jun 7, 2005
alberta_si's Avatar
if he did a swap in a hathc chances are he probably invested in quiet a bit
Old Jun 7, 2005
kezay's Avatar
Yeah but the thing is that in my country most cars even though they have the B18C's and the SR20's and the RB25's etc they don't work properly and most of the cars have major suspension problems, that's why i think that I have a shot. And then again this will be video taped and posted in local magazines. (I want the publicity)
Old Jun 7, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ I don't think the guy would bet $1000 if his car wasn't working properly ...
Old Jun 7, 2005
If you make it so the the race isnt a full straight line. Lets say canyon race? do what i said and you really do have a shot. Driver skill will mean alot on a road course vs drag course
Old Jun 7, 2005
Michalo187's Avatar
Abortion Survivor
Call off the bet unless your gonna do some major weight reduction. Take off the strut bar leave the motor mounts. run slicks try to tune your car you might as well spend 1000 on tuning beat this chump and then get your money back. You better take everything thats not need off. power steering, a/c passenger seats carpets back seat everything in the trunk let us know how it ends up and good luck
Old Jun 7, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hatch would still have the advantage on a road race or canyon, wouldn't it?
Old Jun 7, 2005
jttegx's Avatar
OMNES AD UNUM
^i know those 91 si's do.
b18c1 built > d17a built.
goodluck and do plently of weight reduction. remove every piece of junk in the trunk, even the cardboard, rear seats, passenger seat, panels, etc.
Old Jun 7, 2005
S2000man01's Avatar
O RLY
You will never hit low 14's with the mods you have. low 15's MAYBE. especially without tuning and an aftermarket ECU. your ECU is your worst hinderance.
and I hope you're running premium fuel with that compression ratio. if not, you're probably detonating which can be damaging, not to mention you lose power.
and you're going to lose unless the guy is a total tool and can't drive. a B18C swapped hatch will own you pretty bad.
Old Jun 7, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
B18 in a lightweight hatch has the advantage. Without a dyno you have no idea what kinda power your making. I wouldn't blow a G like that unless I knew for sure what my car was capable of. Just my opinion.
Later
Old Jun 7, 2005
yourinmyw0rld's Avatar
Get ur car tune and dyno and see how much power ur making first
Old Jun 7, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
Good luck, keep us posted up with some results if you do decide to go for it
Old Jun 7, 2005
diskreet's Avatar
thats tough. those are light and B18s can get fast.
anyway strip the car, but I cant see the point of betting $1000 on this. too risky.
Old Jun 7, 2005
1320Racing's Avatar
1320Racing is an unknown quantity at this point
You might wanna make sure your putting down the number's with your set up. I think 14's are def possible with your set up but have you ran it at the track yet. Def get that thing on a dyno and when you run him you better be driving a shell.
Old Jun 7, 2005
kezay's Avatar
Thanks guys for the support and advice but I think that I am going for it..... And BTW I will be using race fuel and also gut the car as much as possible...
Old Jun 7, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
i say ur gonna loose no offense, but higher hp engine in a much lighter car.....it's a given
Old Jun 7, 2005
blouisgod's Avatar
Life Begins > 6800rpms
I had an ek9 project car for a while with the stock d16 in it with mild mods and extreme weight reduction ghetto style, and it romped lots of good cars rolling on 14s. i say dump everything you can, dash, passenger seats, rear seats, deck, everything. hit the trunk to.
what trans do you have? mt/at? what size tires, rims? get some small, light wheels... only if you had a ecu & tune
oh man, good luck out there.
Old Jun 7, 2005
S2000man01's Avatar
O RLY
without tuning or some kind of engine management system, race fuel is just going to prevent you from detonating. in other words you might get an extra 5hp.
dude, seriously. don't put money on this. you are gonna get owned hard.
Old Jun 7, 2005
kezay's Avatar
I know and I have a M/T
Old Jun 7, 2005
dalaw's Avatar
Bone Stock!
No way is a mad weight reduction on the 7thgen is gonna be lighter than an old civic hatch, plus there is no way a built D17 will outpower even a stock B18C.
Old Jun 7, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
When is the race? I think you're crazy but good luck buddy.
