custom intake heat shield
Old Jun 7, 2005
It started as a post fastener at home depot. I glued on thermotec exhaust wrap to the bottom and covered with electrical tape (fibers were shedding everywhere). Then painted it hi temp black, let dry overnight, and set it on top of the filter. Seems to be holding in place but we'll see once I drive it. Not too ghetto I hope??
Old Jun 7, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
does it seem to help at all?
Old Jun 7, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
^ yeah, what he said!
You might also want to use heat wrap on the rest of your intake and your headers.
Old Jun 7, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Is it just me, or is that more of a heat trapper or even an air blocker than a heat shield. I'm just thinking hot air rises. All the other intake heat shields seem to have their openings on the top. I like ghetto and free or cheap stuff. I think it might work better with the opening facing up and little bit more breathing room.
Old Jun 7, 2005
the main worry was that radiator hose which made the bottom part of the filter super hot compared to the rest. Header isn't that bad actually, but the intake pipe does get burning hot. I haven't driven yet, but I will tonight and see if the filter still feels hot.
Old Jun 7, 2005
Titleist71's Avatar
Gearbox, I would do this...take the intake pipe out...thermal wrap the bejezus out of it......wrap all the other things that could be and make the box only open to the area that would bring in fresh air. My K&N box seals out the hot air and is open to the ducting that brings in the cool air. I think just making the shield will keep the filter clean...you may still be sucking the hot ambient, stagnent air.
Old Jun 7, 2005
Logan3024's Avatar
Gearbox why dont you just remove your grill cover, it will allow more air into the engine bay and help to get rid of some heat. I was amazed at the results when i removed mine, especially in the winter time. I would drive 40 minutes to school and there woundnt be any heat transfer to the intake, still cold like it was sitting. But now thats its summer there is NO escape from the heat! My intake gets to hot to even touch, good luck with your project though.
Old Jun 7, 2005
thanks everyone. my main concern was blocking the radiator hose from nearly touching the filter. I know its not a real heatshield and the filter is in the worst spot to make one. Almost no room and sitting in the middle of the engine bay almost. I don't wanna wrap the intake tube cause that's ghetto. DIZZLE, i would remove the cover but its actually molded as part of my upper grill. So I would have to take the whole grill off--again very ghetto.
Old Jun 7, 2005
actually the intake still does quite well when its 90F and everything is too hot to touch. So I guess I'm gonna wait for winter anyway
Old Jun 7, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Im telling you Evo hood! turn that box the other way, and yould almost be set. then you could run a blower fan from that box, to try and push some of the air inside the engine bay around.
Old Jun 7, 2005
and i keep telling you no money. lol. That shield only cost me $10.
Old Jun 7, 2005
get a haircut and get a real job. ha! Nah its cool. Oh did you try adding a vavle to you coolant lines that run into your throtle body? (cant think of the name right now, brain fart)that might help cool the temp. of the intake down a little.
Old Jun 7, 2005
also have you tried fliping the box around so the flat part is underneith?
Old Jun 7, 2005
i like how it looks now. And flipping well it won't stay attached to the filter. Idk, I might take it off if it doesn't work out. I'm kinda worried about the e-tape falling off. I'm gonna drive it tonight and see what happens.
Old Jun 7, 2005
runner1738's Avatar
so how is the typhoon working out for you gearbox?
Old Jun 7, 2005
i'm very happy with it even in the 90F weather we're having. Better than fipk and aem sri by far. I'm still tryin to schedule a dyno this weekend.
Old Jun 7, 2005
zen_master's Avatar
nice...
im waitin for the result...lol
interested in one too..
Old Jun 7, 2005
flqu05's Avatar
flqu05 is an unknown quantity at this point
heres one that actually works.
Old Jun 7, 2005
Well I took mine off. Afraid something was gonna get sucked in from the back and tape falling off. I doubt it would've helped.
And that one up there? No way will that fit on my filter. There is .5 in of clearance around it.
Old Jun 7, 2005
flqu05's Avatar
smaller filter.
Old Jun 7, 2005
dariusld's Avatar
Looks like your mom lost her vacuum cleaner
Old Jun 7, 2005
Hayz's Avatar
well the intake shield does look a little ghetto, but you made it look clean. As far as will it make a big difference I'm not sure but I kinda doubt it...
I agree with him tho ^^^
Old Jun 7, 2005
runner1738's Avatar
why do you say its better then fipk if he seems to heat up more and get realyl hot?
Old Jun 7, 2005
i didn't like the fipk for 2 reasons.
1. too loud after 3k rpms (typhoon is quiet up to 4k rpms)
2. not enough power to justify the noise (typhoon I feel like makes more power)
Only the dyno will tell for sure...maybe cause its mandrel bent?
Old Jun 7, 2005
zen_master's Avatar
just watched the videoo...
i wonder...how it sounds like at 6-7K rpm..............hmmm...
thanx gear =)
Old Jun 7, 2005
runner1738's Avatar
wasnt the fipk cooler though? always have there pros and cons i am sure, arent the aem ones mandrel bent as well, or what is so special about being mandrel bent?
Old Jun 7, 2005
mandrel bent means smoother airflow. not just for exhausts. fipk i guess was cooler, but you have to think, that heat shield will eventually become hot or air will move around it. The filter is still in the engine bay. Also I didn't like how the fipk sounded. It was actually louder than the typhoon imo. Aem I don't know what happened there cause low end was horrible. Maybe pipe was a tad bigger. The typhoon has amazing low end for it being 85 outside now and alot hotter underneath the hood. I think in the winter its gonna feel like a turbo I'm hoping for at least 5hp/5tq from dyno.
Old Jun 7, 2005
runner1738's Avatar
so im guessing you have a dyno with your car before the typhonn?
Old Jun 7, 2005
yup. That's the 100whp one I got but that was when it wasa colder so we'll see. It's gonna be alot hotter this time around. Things that changed are typhoon, aem pulley (ps only), fp60 fuel additive for a month, kamikaze header instead of ebay (same port size). So really the only thing that would give hp is the intake. pulley maybe 1.
carid
Nov 7, 2015 01:46 AM
herbiej
22
Aug 23, 2015 01:02 PM
mrwhos
Aug 11, 2015 02:03 AM
muttleytm
Jul 11, 2015 06:00 PM
Bounddyy
Jul 8, 2015 11:22 AM
