front Koni blown
Old Jun 3, 2005
Diablo's Avatar
Diablo is an unknown quantity at this point
front Koni blown
This will be the 4th time i have to replace my front Koni . for some reason the freeking struts keep leaking oil from the adjustment **** . Does any one know what could cause this? Has any one had this problem with there koni? and no i have not hit any pot holes.
Old Jun 4, 2005
flotsamm's Avatar
Damn thats insane. I've been on my Konis for two plus years now I think and no leaks.. is it the same side every time or both?
Old Jun 4, 2005
skipbarber's Avatar
what are you lowered on?
Old Jun 4, 2005
Diablo's Avatar
Im lowered on h&r about 1.5" Ive had both replaced but this is the same side ireplaced 2 month ago. every one with koni should actually feel around the **** where they get adjusted or look and see if you see oil.
Old Jun 4, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i hope you had your previous ones covered under warranty.
who installed the suspension?
either way, i would call up koni and complain
Old Jun 4, 2005
Diablo's Avatar
yes i have, warranty was never a problem except i have to pay for shipping the bad one, and they charge my credit card for the strut then put the money back when they receive the old one and i get stuck paying for the interest.
Old Jun 5, 2005
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
Ive had no problems with my konis for a year and half now. I cant think of why you keep getting the problem unless they were not properly installed or maybe if you keep adjusting the stiffness setting, maybe thats y they r leaking oil from that spot.
Also, when you get your next set, set them to a middle setting, dont put them as hard as they can go or as soft as they can go cus that puts extra strain on them cus they r operating at an extreme.
Old Jun 6, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
why do i always hear about konis getting blown but i havent heard of tokicos getting blown?
Old Jun 6, 2005
wonderz's Avatar
wonderz is on a distinguished road
most of the time its due to improper installations...
Old Jun 6, 2005
Diablo's Avatar
i always keep them about 1.5 turns from soft so i know that isnt the problem. and they are installed the right way. the only thing i can think is that the plastic washer they send isnt thick enough to keep this from hapening. thats why they have it to keep this sort of thing from happening.
Old Jun 6, 2005
Zzyzx's Avatar
Autocross Junky
Wierd, I've been running Konis for about a year now, and not a single problem. and I'm not exactly easy on my cars suspension either.
That little white plastic washer btw is just a safty part so that if you do bottom the shock out it doesnt try to suck its self appart when the suspension extends.
Old Jun 6, 2005
Well then i hav no friggin idea, sucks man
Old Jun 28, 2005
Diablo's Avatar
well KONI told me that they keep having that problem with the 55mm strets and that having the car lowerd could also cause it. **** i only have H&R spring i guess i can forget about getting the neuspeed springs i want. well I put on the replacement they sent and the freeking strut is worse than the one i sent them. KONI SUCKS. im thinking if getting TEIN full coiloverkit has there been any isues with them that any of you might know?
Old Jul 2, 2005
7thGEN 2nv's Avatar
7thGEN 2nv is an unknown quantity at this point
u pay so much for konis, and at the end they just disappoint u. i sold mine and will try the tokico blues. good luck
Old Jul 3, 2005
Diablo's Avatar
Thats right.
Old Jul 3, 2005
wonderz's Avatar
at least they have life time warranty...
imagine that happens to Tein SS after a year, you are pretty much stuck 'cause their warranty only last a year...
Old Jul 4, 2005
18inchpride's Avatar
18inchpride is an unknown quantity at this point
koni is lifetime warrenty
7thgensurvivor
38
Aug 29, 2015 11:50 AM
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
rhyno
Nov 27, 2001 10:07 PM
