check engine light question
Old May 31, 2005
Nelly's Avatar
Nelly is an unknown quantity at this point
alright...i woke up this morning, started the car, it started to make a slight rumble like it was going to idle out, than the check engine light started to blink about 3x and than it jsut stayed on.
now,...i took off the air box off about a year ago. so i can hear the v-tec more with no intake kit installed or anything. could this be a rpoblem with air flow or somehting more serious. if theres any experts with this situation, i'd really appreciate some input,...thanx
Old May 31, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
so your saying you have no air filter at all on?
if so, i would either put the stock air box back on, or buy an intake system for your car because you need some sort of filter to keep the dirt out of you engine
Old May 31, 2005
Nelly's Avatar
well i have the air filter box there but not the intake box the huge black thing that leads tot he air filter
Old May 31, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
Check engine or Main't Req'd light? i dunno about the check engine..but if its main't req'd...do this...
1. hold the button that resets the trip while the car is off
2. turn key to II position (2 clicks, but don't turn the car on) while holding button
3. keep holding the button for 10 seconds
4. after 10 seconds, turn on the car while button is still being pushed
5. wah lah - no more light
that should do the trick. you're welcome
Old May 31, 2005
neocivic01's Avatar
the Rage
neocivic01 is an unknown quantity at this point
if you cant figure it out just got to a honda dealer and they should do it for you. thats what i did.
Old May 31, 2005
Nelly's Avatar
what did that cost you?
going to the dealer
Old May 31, 2005
JesterMasque's Avatar
...ever grinning...
JesterMasque is an unknown quantity at this point
Taking the resonator off shouldn't do anything to the motor. I't merely to keep things quieter and get a little bit cooler air to the intake. And if it's not the "Maintenance Required" light then that process won't do anything. You should take it to AutoZone or PepBoys cause they'll check the codes for free.
Old May 31, 2005
streetglower's Avatar
I guarentee you your air filter is clogged to **** with dirt. A guy at my school did the same thing and when he checked the air filter, it was black with globs of dirt.
Old May 31, 2005
...ever grinning...
That too^
Old May 31, 2005
but are you sure it is your check engine light? Having the light blink 3 times and then stay on sounds like the maintenence required light? Is the light a picture of a engine or does it say maintenence required?
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
thana
Jun 15, 2020 07:05 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
