programming remote
programming remote
I have noticed on ebay people selling there old or used remote keyless entry buttons, but some of them say they have a sheet that will tell you how to reprogram it, i thought you had to go to the dealer for that? is this true, if so anyone know where i could find a copy of that sheet, i have already asked the seller where he got his, just wondering if anyone knows on here
turn the ignition switch to ON position, marked II
Press the LOCK button
Turn the ignition switch to ACCESSORY position, marked I
x3
Turn ignition switch to ON for a fourth time
Press LOCK, the door locks should make a cycling sound
Press LOCK once more to program. If you have multiples, press LOCK on each one in turn, all must be programmed within ten seconds of each other
Turn off ignition and remove key. Your remotes should now be programmed
x3
My Baby Daddy
sbi
Sep 2, 2015 07:44 AM
