help with koni yellows.(I searched already!)
Old Apr 27, 2005
sifusexc's Avatar
sifusexc is an unknown quantity at this point
so im trying to install a set of koni yellows on my car. i tried the rear first. for some reason, the actual shock does not fit into and go through the top mount. It doesnt pass the metal collar inside the rubber bushing in the underneath of the top mount. I did some research and from what Boilermaker is stating, is that konis work with every year of our cars, especially the rears(with no problem) Is there anything else i need to look for? Any help would be greatly appreciated. thanks.
Old Apr 27, 2005
scatman's Avatar
Still in the game...
umm, i thought the front struts have to modded to house the koni's.....is that where ur prob is?
Old Apr 27, 2005
sifusexc's Avatar
nope. im talkin about the rears. the fronts in my kit are already modded and good to go. not installed but should be ok
Old Apr 27, 2005
scatman's Avatar
k, i gotcha...not too sure about the rears tho
Old Apr 27, 2005
sifusexc's Avatar
thanks anyways man, anyone else have anything for me?
Old Apr 28, 2005
MiamiUgen7's Avatar
bump for the dude i sold my shocks to.
Old Apr 28, 2005
flotsamm's Avatar
You mean the top of the shock piston(where the threads and adjustment screw are) is to big that it wont go through the metal collar thats surrounded by the rubber bushing in the mount? It should... weird. There should be more then enough thread sticking out that you can get the bolt and washer on it without any problems. Maybe get the part numbers off the Konis and verify that theyre correct ones? Dunno..
Old Apr 28, 2005
sifusexc's Avatar
flotsamm, u are correct. its not that there is not enough thread, its just that it wont go through at all.
Old Apr 28, 2005
MiamiUgen7's Avatar
did you try using the washers that were in the box?
Old Apr 28, 2005
MiamiUgen7's Avatar
btw, these were in an 03 coupe before, so they should fit in his 03 sedan. does anyone know what the problem could be?
Old Apr 28, 2005
Zzyzx's Avatar
Autocross Junky
This may help
http://www.hondatuningmagazine.com/t...ht_suspension/
Old Apr 28, 2005
sifusexc's Avatar
yeah. ibeleive the washers in the box is the top washer, the real question I suppose is,
do I take out the metal collar since the konis are wider in girth than stock?
miamiugen, no ooffense man, im just tryin to get this figured out dude
Old Apr 28, 2005
Zzyzx's Avatar
Autocross Junky
Which part isnt fiting?
#2?
Old Apr 28, 2005
sifusexc's Avatar
im on my palm right now so the illustration is way too small for me to see. ill reply and let u know the number wheni get back home. I've already looked at the hondatuning install but that doesn't help
Old Apr 28, 2005
sifusexc's Avatar
yeah. it is number two. do I just take It out? because it is definitely not going to fit on the konis
Old Apr 28, 2005
Zzyzx's Avatar
Autocross Junky
Take the konis to a honda dealership and find a verson of Part #2 that does fit. Its a spacer and it's probably not a good idea to not use one. You may have the kit that is designed for an erlier civic or possibly the RSX or Si.
Old Apr 28, 2005
sifusexc's Avatar
alright, zzyzx, i appreciate the help.
Old Apr 28, 2005
flotsamm's Avatar
I looked at my Koni instructions(they suck btw) and that piece your referring to comes from Koni. It comes in the hardware bag. The stock one wont fit. Here a couple of pics I took with my camera of the instructions.. sorry no scanner lol.
Now gimme all your points! lol j/k
Old Apr 28, 2005
sifusexc's Avatar
wow, thanks man, i really appreciate u going out ur way to help. u can have my points, dont mean **** to me.
Old Apr 29, 2005
boostaddict's Avatar
boostaddict is on a distinguished road
Yea, I had the same problem. I just got creative (got the stuff used) and found a bigger sleve from a different set of shocks (off-road) I had laying around and found washers with a bigger ID, and then just shoved the sleve through the stock bushings. For the shock to work you NEED to have the stuff going in this order (bottom to top): shock shaft, washer, bushing, sleeve, car body, bushing, washer, nut.
Tedverseti
Apr 23, 2020 01:45 PM
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
