who gets clicking noises from axles?
ThE FaMiLy SeDaN
when i turn... especially turning left after long highway trips my axles click.
like a pop pop pop its rotational noise..so idk
i took them to a CV place once and they drained em and checked the ***** and redid em...
but im getting popping noise again
anyone else get this
rotational as in faster it goes faster.. and its click click click.
riley
riley
anyone ever get a loud clank noise when you first brake either in revearse, or in drive after revearse, like something shifted, then jumped forward or back in place when you brake??? WTF is that?
myspace.com/misterwarren =]
i hear it randomly.. i think its the sound u 7thgen-ers are talking about.... when i go over speed bumps on the front end.. or sometimes just out of nowhere . is it the same problem?
ThE FaMiLy SeDaN
yeah mines turning right too.. i thoguth twice about it..
also i get the brake noise...
but i have 4 pot brakes... and its only driver side..
****ing weird noises.. the axle one scares me .. i dont want it to snap or something yanno
ThE FaMiLy SeDaN
i think maybe when we turn right,.. it pulls the axles somewhat out of the CV and then it slips or somethng idk.. i dont feel a loss of power when i do it so i dont think its like spinning inside just maybe hits something idk
riley
riley
apparently there is official report from honda or somthing about this, its some bearing at the top of the strut housing or somthing... there shitty... my mechanic was rambling about it but i wasnt paying attention... he changed em when i did my springs/struts and it never did it again
Originally Posted by streetglower
what do you mean they drained them and checked the *****? All that is in the axle are CV joints. If you have them rebuilt, you need new joints and what not. Most shops usally replace the axle. sounds like the place you took it to just regreased them or something.
the axle noise when turning ( dont know if it was addressed) is the drve axle. I break them 2-4 times a yr. but if i dont snap them like i do on the fast civic i have, the only civic used to loose grease and would rub metal to metal and cause annoying clicking noises. mainly from the drivers side. that tends to have more stress. once it starts clicking you cant reverse it.
just hav to replace the axle. shouldnt be anymore than 150 to get done. mines ( 98 gsr is 60 + core of 70 and free installation) so your shouldnt be about the same plus installation. look around, you can get ones with lifetime warrenty. just dont tell them you race if you do
good luck
good luck Titanium Metallic. You got a problem with that?
I have something pop/crack quite often when I slow to a stop and have the wheel turned to either direction. Dont know what it is, figured it would stop with the replacement of the OEM setup, but that hasnt happened yet.
ThE FaMiLy SeDaN
yeah sounds like we all have same problem what the hell is it.. this is why im selling my car cause i cant find a cure.
i even drove on ramps and the axles are straight and they dont hit anything.. ugh
7th Gen Photographer
if you guys have 01 civics... your strut bearings are teflon/plastic stuff. they may crack with the added stress of a really stiff suspension. this would cause a popping sound when turning the wheel sitting still or at low speeds. also rijowy... its prolly those big friggin rims
I stand corrected... I dunno about the axle thing... lol... the clicking I'm talking about happens when you turn the wheel sitting still or at low speeds... it's not rotational.
i have that same noise too.. been to honda maybe 3 times to get it checked out. it only happens to me turning sharp and slow.. ie. in a parking lot or going in/out into a driveway. it is annoying!! happend since day 1. Honda said they "tightened" my whole front right side, now the noise happens turning left also... is there a link to that official report from honda so we can throw it in the dealers faces?
lol sounds like you guys need u-joints...............jp
dunno if this has been addressed but since they just rebooted your axle not replaced it, the bearings in the joints might be worn and so thats whats making the noises probably because without lube in their things will not work the right way, (its hard to explain so sorry if i seem like a moron) its not the axle popping out however.although im kinda not sure what you mean because i dont think this would only happen after highway trips
now a days its more common to replace them due to labor cost compared to parts cost.
oh and for u guys talkin bout the ***** and whatnot, when an axle has a ripped boot it looses all its grease, then if the axle is not destroyed from this depending on customer preference and cost they will reboot it which means they check the ***** in the bearing inside and if they are ok they reagreas everything and reboot it, you can buy the boot and lil hardware for like ten bucks at honda if u ask.
oh and i have a dam squeaking noise over bumps its not really high pitched sounds kinda like rubber on metal, im still tracking it down, plus today a really high pitched one started that just goes like non stop over any bump
Sep 26, 2023 06:44 PM
Green02civic
Jul 27, 2015 10:48 PM
17
Jul 23, 2015 11:48 PM
