Top mount bolts won't come off...help?!
Old Apr 11, 2005
LiKEaFeRiO's Avatar
I was unbolting the 3 nuts off the top mounts for the fronts so I could uninstall my strut bar.
One my passenger side, 1 nut came off fine, but the other 2 was a bitch.
I kept turning and turning and soon realized its stripped and its stuck.
I went to a local shop and ask them to try using an air gun on it.
It just turns and smokes from the friction.
Anyone know how to fix this without taking it to a shop?
Old Apr 11, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
hmmm only thing i would really try would be to jam a flat head underneath it and try and pry the nut up while u turn the nut by hand
Old Apr 11, 2005
ncirom2003's Avatar
ur fvcked, pretty much leave it or your gonna need to buy a new piece after you remove it, i forget the part name but its not the whole strut lucky you
Old Apr 11, 2005
manahoonie's Avatar
use a dremel wit a STRONG cutting tool. cut the nut on either side, so it would fall in half. (BTW, I don't know how strong a dremel can be.)
Old Apr 11, 2005
skipbarber's Avatar
youre most likely gonna end up having to replace the upper strut mount, or try to get a new stud pressed in. The only way to get it out now is to cut it off. If I understand correctly.
Old Apr 11, 2005
LiKEaFeRiO's Avatar
Thanks for the help guys.
I tried the flathead idea already and its just not doing it.
I may try to find a dremel and saw it in half.
Nigel Evans
Jun 10, 2015 06:35 PM
cukaracha
Jun 4, 2015 07:47 PM
reqy
Jun 1, 2015 07:05 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
thesushiboy
Apr 12, 2015 02:54 AM
