Skunk2 + Kyb Agx= Good or Bad??
Old Mar 23, 2005
Blackness's Avatar
From: Charlotte, NC, But Greenville, NC for School-ECU
Blackness is an unknown quantity at this point
Lightbulb Skunk2 + Kyb Agx= Good or Bad??
Once I get some, good, feedback on Skunk2 Coiloves with Kyb Agx Shocks I think I will purchase the shocks. Does anyone have this setup?, or know anyone with this setup? Will there need to be any modifications for this project or no? THANKS a Million all...
Old Mar 23, 2005
anibal's Avatar
anibal is an unknown quantity at this point
How much is the drop with the Skunk2? AGX are designed to work with the stock springs are a lowering of no more than 1.5" is recommended by KYB. These are very good struts, I love the ride and handling but if you lower them more than that you risk blowing them quickly.
Old Mar 23, 2005
Blackness's Avatar
Will 1.5" is just fine with me. Now if I install the Kyb shocks with my stock spings, how much lower will the car be??
Old Mar 23, 2005
Caucasian.Asian's Avatar
start coming to the forums more often. shocks DO NOT change car height
Old Mar 23, 2005
anibal's Avatar
Same as Stock. Shocks doesn't lower the vehicle unless they've been designed to do so by means of a shorter body or different lower perch position. I already have the Skunk2 springs, well, check how much they lower the car before ordering shocks. If you're looking for lowering springs, you might wanna check the Eibach Pro-Kit or Tein S-Techs which lower the vehicle a bit less than 1.5". I don't know about the others, so you might want to search about them.
Old Mar 23, 2005
Blackness's Avatar
Cool, I just want to know if the Skunk2 Coilovers would fit the Kyb Agx Shock body? Or will any modification needed to be made..?
Old Mar 23, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
skunk2 sleeved coilovers will NOT work with aftermarket shocks that i know of. there was a member here who tried installing KYB struts/shocks on his skunk2 coilovers on his sedan and the KYB strut wont fit thru the coilover perches. and secondly, ive talked to a personal 7thgen sedan owner who also had skunk2 coilovers and tried installing KYB's as well. both had no luck and the strut wont fit thru the coilover perches.
after i figured out myself, i talked to my personal mechanic and he told me skunk2 sleeved coilovers are meant to go with OEM factory struts (not sure if all vehicles, but mine yes). so for us skunk2 sleeved coilover owners, were pretty much fcuked as aftermarket shocks/struts go.
Old Mar 24, 2005
nema84's Avatar
You Sonamabetch!!
nema84 is an unknown quantity at this point
i've heard koni's work w/ them, a couple guys have them on this forum.
Old Mar 24, 2005
danscreations's Avatar
Tuckin' 19's
danscreations is an unknown quantity at this point
By the time you pay for both of them you could almost get true coilovers which are much better! Sleeved coilovers are POS! I think Tein Basic & D2 True Coilovers start around $850. The shocks and skunk 2's are problably around $700 or so....
Old Mar 25, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
anyone with KYB know what the two nuts that come with the fronts are for??
and witch setting it the hardest 1 or 4????
Old Mar 25, 2005
Blackness's Avatar
Well then I guess I will just maybe try to sell my Skunk2 Coilovers and find just a set of springs that will lower my car 1.5-2.0".
Old Mar 25, 2005
anibal's Avatar
Hardest setting is 4 for the KYB AGX.
Old Mar 26, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
The two nuts that come with the front are supposed to replace the stock hardware that holds the strut assembly together on top. You'll notice they're nylon lockers, where the stocks are just plain nuts.
I have to say the best part of the KYB AGXs so far is the abundance of small screwdrivers i'm left with after the install.
Old Mar 27, 2005
well this is what i got only with the fronts, and the nuts donrt have nylon, so they installed them with the stock hardware...
Old Mar 27, 2005
scatman's Avatar
Still in the game...
id never buy anything having to do with skunk2 springs after seeing at least 10 people's springs break.
Old Mar 27, 2005
Blackness's Avatar
Oh ok, well in that case, Does anyone want to buy a set of Skunk2 Coilovers for a LX?? LoL. I think I will buy a set of springs and new shocks...
Old Mar 29, 2005
By the way if i go all the way to setting 4 and pass to 1 again directly, is it even stiffer or does it just return to the softest setting??
Old Mar 26, 2010
FerstlerSlim's Avatar
FerstlerSlim has a little shameless behaviour in the past
Re: Skunk2 + Kyb Agx= Good or Bad??
Anyone have the part number for the KYB AGX for an 03-05 civic (not-si)?
Dave
Old Mar 26, 2010
Traffic signs are universal - red means stop or danger, but red in the shocks means STIFF!
Verde es para flojos, hombre!
Old Mar 26, 2010
calate, pendejo... esta loco?
Old Mar 26, 2010
Dave
go to Kayaba home page and search...
took me 2 minutes of hard typing to find theses. Do you know where the search portion is? look at the top.
http://www.kyb.com/pdf/kyb_catalog.pdf
now you can leave your couch and carry your 500 lbs around, please. typing requires only your fingers...
500 lbs Slim...
Old Mar 27, 2010
sureshot1979's Avatar
sureshot1979 is an unknown quantity at this point
well first of all go ground control coil overs with eibach springs then kyb gr2s its a stiffer ride but way better feeling then skunk2 or pro comp. k sport has some realy good **** out there aswell so does billstein
civic1316
May 29, 2015 05:13 PM
Tybonater
Apr 24, 2015 07:03 PM
dooner24
Apr 14, 2015 07:51 PM
Elusiv1
Nov 8, 2001 09:55 PM
