5000k for oil changes?
Well i got me a 2005 lx sedan, and the dealer said there is no more break in period and the oil should only be changed every 5,000, is this true and best? also i usualy get my tires rotated everytime i get the oil changed? is that also a good time? rather then 3-4k as it as before
Don't do your first oil change for a good 5000 miles or so. The oil from the factory is different than standard oil. It's high in moly content to help the engine break in and seal properly.
Breakin time is a topic of high debate with no real honest answers, so basically.... drive it how you are going to drive it for the rest of it's life. That's the best advice I can give.
As for oil change intervals, on regular oil, 5000 is fine, on synthetic, you can go probably 7500+ miles between changes.
ok just with my 02 i did that one like every 3-4 and yea that one had break in oil, this one supposedly doesnt, comes with some special already filtered oil so no shavings in it or something
the oil that comes from the factory has nothing to do with metal shavings or filtered oil.
it uses an addative called molybednum (spelling?) which helps coat the engine properly, create better seals, and help the engine break in process. the dealership that told you there is no breakin period is full o crap.
lol i seemed to know more about the differences in the cars then they did , all they know is price and how much they can get from you , thats about it
counting miles on to your next oil change varies. some drive hard, race, just cruise, drive like grannies, etc. it depends on your driving habits as well.
my driving style is spirited/daily driver. i get average of 5000 miles off fully syn mobil 1 motor oil (5w30). but i change it whenever its a very dark brown texture or even sooner.
every 5000 man, your safe...I go 5000 usually, the manual says 10,000 for normal driving - I drive a little hard on my car, so 5000 - 7500, usually always 5000, I use 5w-20 and a purolator filter...don't listen to the fools on here that say change your oil 3000 miles, read the honda manual and believe it.....
Put 500 miles on it and take it back to the dealer for your free oil change. I would recomend oil changes every 3k with regular oil and 5k with synthetic. The car only takes 4 courts. A large debate is the viscosity to use. I would recomend using conventional 5w20 oil for the first 15k and then start using synthetic if you are one that uses synthitic oils. This allows the engine bearings, piston rings and the valve train to properly wear in. I see you live in California which has a tropical climate, alot of people use 0w20 oil, for what reason I dont know, this is like pouring water in your crankcase, its very thin. If your going to use synthetic oil I would suddgest 10w30. Synthetic oil is known to be thinner than conventional oil anyway so a little thicker oil in Calilfornia would be perfect for you. If your not one to change your oil walmart is cheap, 30 bucks for Mobile 1 and 17.00 for conventional oil. I recomend the first change at 500-1000 because of all the assemble lube used during assembly, also if there were any burrs or trash that got loose after assembly you can get rid of them quickly. Genraly like the other guy said, there are alot of moly additives used during assembly because it bonds to metal, after several hundred miles it is no longer needed. This is just my two cents, its your car though, but this is how I have maintained my car, the engine is the only part of the car that I have not had any problems with so far and I have 45k on it now. The rest of the car has given me nothing but headaches! Good luck with yours!
Originally Posted by 12sec elcamino
Put 500 miles on it and take it back to the dealer for your free oil change. I would recomend oil changes every 3k with regular oil and 5k with synthetic. I recomend the first change at 500-1000 because of all the assemble lube used during assembly, also if there were any burrs or trash that got loose after assembly you can get rid of them quickly. Genraly like the other guy said, there are alot of moly additives used during assembly because it bonds to metal, after several hundred miles it is no longer needed.
i have no idea why you'd change the factory oil at 500 miles. wait 5000 miles, and allow the moly/factory oil to do its job.
and dont change the oil every 3k with dino and 5k with synthetic.
even driving hard, 5k on dino oil, and 7500 on synthetic at LEAST.
so whatever honda says about there vehicles is the best answer?
every mechanic ive talked to changes there oil at LEAST every 5k, most of the time its 3500 miles. it wont hurt to change motor oil sooner than expected, only loss is your money. im not saying honda is wrong, 5000 miles per oil change is perfectly fine. i would rather let my engine eat up good fuel than dark brown worn out oil with no fresh addictives every time i drive.
"so whatever honda says about there vehicles is the best answer?"
When they've got nothing to gain by making the statement, then yeah, they built it, they should know. 10,000 is a little long for comfort on a dino oil, but i'd run Mobil 1 or equivalent to 10K and not think twice. You'd think Honda would recommend a shorter OCI just to help line the service manager's pockets a little thicker, but I guess not.
yea, when you look in the manual or go to honda they claim that our civics can go 5000 between oil changes. every 3000 and it should be changed, unless using synthetic, period
no robbclark is right. 3k changes are a thing of the past. even fords go 5k now on dino oil. 3k = pissing money away. if you change it every 3k, you might as well change it every time you fill up with gas, cuz it's gonna have the same effect.
i dunno i always change my oil every 3 thousand like i have been in my hatch and previous cars .. and i change my tranny fluid every 10 thousand .... but i race my car so ... i push it hard ... as for break in i didnt push it hard for a good 500 - 600 miles .. but thats just me old habbits ... i also run royal purple oil and tranny fluid ... and i use a oem oil filter
That's what I did - my 01 is now at 112,000 miles and still going strong. I usually change oil at 4000 mile intervals after the first 5000 mile oil change. I might even drive this car to 200,000 miles or more.
Turbos, Engines, Chassis and Suspension Tech
Originally Posted by rolla
hey, i only have 4100 KMS on my car thats 2500 miles
the manual tells me to change my kms at 8000 or 6 months
well its been 6 months, u guys think i should still change it with such little kms?
i would just to be safe. was the vehicle stored or something? if its been driven at like once a week or so, then it may be safe. but do it anyways, rather be safe than sorry.
S2000 is correct 5000 Km's is pretty good....
if you put an average of 25000km's per year on your car then thats 5 oil changes..
Enough for me
Enough for me
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
CdnRD
Aug 21, 2015 11:42 PM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
