plug burnt OUTTTT
plug burnt OUTTTT
hey guys i had some cheap bulbs..that made it look blue. So after a few weeks the bulbs finally burnt out when i went to take them out to exchange. they were melted onto my plug.......so my whole plug was melted....so i had to take apart the plug and right now i have the three connections connected to my bulb without the plastic plug. Do i have to get another plug because i dont get enough light out of that bulb without the plug. i used the word plug a lotttt of times......Could it be the bulbs i got now require to much energy......but that doesnt explain why one is bright other is not. They are Nokya Artic Purple 8700k H4 thanks for the help.......By the way how much do i pay for a plug at the dealer?????
well your problem is that you bought ricer bulbs. next time do some research and you'll learn that higher K doesn't mean more light output. it just means more problems.
you prolly bought hi wattage bulbs and messed up your electrical system. Good luck. I doubt a new plug will help if the wires are melted from the extra current.
I dont get as much lighting as i do from the right side headlight.......I changed the bulbs and its gotta be the plug. I got one of those cheap immitation bulbs then after that burnt out i Got Piaa and nokyas. But after it was burnt out the plug just kept on melting.. How much will the whole plug cost me along with the wires which i think i need right???? Also the wires on the plug look normal not burnt or anything????Thanks for the help guys
I dunno im buyin these nokya yellow lights their suppose to be low wattage.....But do you guys think i need to buy the plug and the whole wires????and how much will it cost me???? i guess i need the whole harness right???sorry for so many questions thanks guys..........
Replace the plug first to see if it fixes it. Otherwise, your wiring is fried and that will be very expensive to fix. I have yellow nokyas and they're stock wattage.
Yeah you probably damaged your harness/plug when it melted.. Like gearbox said, try replacing the plugs first because although the wiring looks find.. the plug itself might be internally damaged.
Oh ya, try some other bulbs cuz those ones probably run at a way higher than stock wattage..
What year is your civic by the way? Might want to get Honda to check out ur wiring harnesses cuz I remember reading that some might have a recall which was about the harnesses melting.
i got a 2001 civic ex 2 dr M/T .........Well im going to try the yellow nokyas maybe they dont need that high of a wattage to run.... because the nokyas purple i got are both runnin but the side that the plug is already missing lights a little dimmer.
Nokyas Purple ( the ones i got on now)
Bulb Type: H4
Wattage (draw): 55/65
Wattage (output): 80/100
Color: Arctic Purple
Color Temp: 8500K
Nokyas yellow ( the ones im going to get)
Bulb Type: H4
Wattage (draw): 70/80
Wattage (output): 70/80
Color: Hyper Yellow
Color Temp: 2500K
So it might light regular becuase not that much wattage output right???
how much will the plug run me??????
Bulb Type: H4
Color Temp: 8500K
Bulb Type: H4
Color: Hyper Yellow
Color Temp: 2500K
hey guys i got the yellow light bulbs by nokya.....they look tight...one of them is a little bit dimmer. But you cant tell difference unless u turn high beams on....So thanks for the help guys.i guess ill just get the plug.
I didnt get the plug im just running the wires to the bulb.wit electric tape..... i seem to be gettin just a tad less power....But barely noticeable.........i like the yellow nokyas but the visibility is horrible. How much Hids will run for 2001 civic????
well, if you searched you could probably find your answer in less than 5 minutes
but since i'm such a nice guy, look at the retail section (for sale/trade) and you will find the XTEC/Prolumen HID sale.
fecrni
Aug 8, 2015 06:15 PM
DerbyDad03
Jul 27, 2015 11:34 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
beeemerdude
Jul 10, 2015 09:22 PM
