to bore or not to bore TB?
Has anyone had success with a 5mm bore on our stock 60mm throttle bodies? I'm talking an N/A setup.
I'm getting a P&P Head and some ppl like 'Gearbox' say to not bore TB, so should I get a 5 angle valve job and retainers rather then the bored TB
I plan to get my tb bored out. I have never seen and engine that has not responded good to one once tuned. It usually carries a 2-5 hp gain all through the power band. If I am wrong, hell its only 100 bux to get it done.
Originally Posted by Killacamshaft
port the exuast side bigger the the intake
djmota? Did you get any specs from your mechanics or note anything of interest, when you got your head p&p'ed what Hp gain did you get just from the P&P?
from my point of view, if you look at all the things that make your car or hold your car back, i see the tb as one of the most or last things to change...
your car is making only say 130, and its not because of the 60mm throttle body. i would find much more important things to do besides the tb. and by saying its only 100 bucks, well 3 tb ported can get you higher compression pistons. that would do more things than a ported tb will ever do...
find something else to spend your money on...jsut my .02
Originally Posted by Tomola
Who told you this? Does anyone have some specs/ratios/%'s? As to how the bore work should be done on our D17's?
this i never heard of but actually makes sense....
for the same reason as my exhaust piping is bigger than my intake piping..
hot air expands... so the same volume of air comming in would need more room to leave since its probly sevearl hundred degrees hotter... thus needing bigger exhaust ports than intake ports
talk to grey. he tried the diy tb bore and it didnt really work out well from what i remember. im not sure if he did it wrong, but i remember him saying that it was a mistake to diy that, or something to that effect.
i am not a huge gearhead, but im not sure the tb is the biggest restriction the d17 has. sure, it might give you some hp gains, but im sure you can find something more worthwhile to improve. not sure if youve modified it or not, but the intake manifold is pretty restrictive from what i understand.
have you done any flow tests? you should work on whatever is the most restrictive part. but thats just my opinion.
Wanna see a donkey show?
Exactly!! One of the many important things you must know when modding, what are you trying to achieve, also you do not do one thing with out matching it to other mods to get the most of each mod. I.e. just port the exhaust side.....you should then have the intake side touched to match the flow from the exhaust, cam should follow to match to the flow setup of the ports. One of the mods I do not have a clue about is turbo's. That is what I would look into before N/A. But no matter what you do you should always ask what I am trying to build. My .02c over
Originally Posted by djmota
get the valve job and retainers while you have the head off. You can always bore out your throttle body later.
The valve job will help air flow past the valve better. Lighter retainers will help the valves close quicker and lighten up the valve train a tad.
The 10 hp from the pnp was untuned, running rich.
7thgen Power Maker
On the D17, I say no. Don't bother. All motor D17's are not worth it. Spray or spool to really play.
Originally Posted by dezod
All it does is lean out your A/F ratios, thus making more power. That's all.
eorlando1
May 17, 2015 11:16 AM
