Finishing some small mods *pics*
1st off sorry to use the word mods like that i dont want to sound retarted.
So far last night (friday to 2:30am saturday) I have:
*Finished painting eyelids / eyebrows (installing in spring, only checking color now)
*Painted altezza grill (drying now...install tonight)
*Installed color matched hood molding
*Revearsed L brackets on sub box to conceal bottom of metal bracket under box
*removed board behind seat and re-mounted (4 screws, 7 zip-ties
Anyone know how to get the tape off the grill without it pulling all of the paint off in big flakes? should i get a razor and slightly cut the edge between the tape and paint?
)Anyone know how to get the tape off the grill without it pulling all of the paint off in big flakes? should i get a razor and slightly cut the edge between the tape and paint?
razor would probably be your best bet. but you didn't use painters tape?
how is the color match? what part #/color and where did you get the paint?
I believe the best way to remove tape is to do it when the paint is still wet, that way you can get a clean sharp edge. Once paint dries, it will stick to the tape, making it one with the fresh paint.
Sorry To Keep You Waiting!
1st I ended up using a razor to cut under the tape and it worked pretty well, but I do have a little obvious edge between paint and plastic thats only visible within 1 foot or less. So its not perfect but it looks good either way. plus for how bad the paint is on my car it doesnt matter.
previous owned sux with paint!
The only reason civic01vtec I have this time is cause spring break is coming up and the parents left for the weekend which means I can do whatever I want and dont have to terrify the mom with all the loose parts!
Paint is Duplicolor Artic Silver Metallic (matches SSM almost perfectly from more than 1 inch away)
In these pics keep in mind hood molding is SSM from honda and grill + mock-fitted eyelids are duplicolor.
Keep in mind eyelids wont be installed till better weather cause I dont want them getting too salty and stuff now...but grill couldnt wait!
Sorry it took so long me and my girlfriend spent some time together for once cause school is crazy now. thank god for spring break.
previous owned sux with paint!The only reason civic01vtec I have this time is cause spring break is coming up and the parents left for the weekend which means I can do whatever I want and dont have to terrify the mom with all the loose parts!
you should use some clear coat on the grill.
thanks for the advice, but I had to use a razor cause its too late. The tape is painters tape or whatever 3M calls it.
As for sanding I sanded it with 400 grit then 800 then cleaned it then painted. Didnt have time to sand between coats but Its on a car that has bad paint already so I dont mind at all.
LOL thanks guy for such little mods these took alot of time and money $50 for eyelids and grill and $30 in paint and supplies!
But it was worth it and even though the paint is far from perfect on the grill it looks good enough and I saved a few $$$ from getting it painted by someone else.
I cant wait for my 16" HFP wheels and to install my eyelids once april rolls around
Sep 27, 2015 11:33 AM
pilebuck13
Sep 21, 2015 10:45 PM
Touge
Sep 18, 2015 12:13 AM
Balkos
Sep 11, 2015 11:39 PM
redcloud
Sep 7, 2015 01:45 PM
