bad shake when i start
Old Feb 27, 2005
02CivicRider's Avatar
02CivicRider is an unknown quantity at this point
after i installed the megan high flow cat everytime i start my car theres a really bad shake coming from the exhaust somewhere. it only does this after i drive for a while and park the car for a while. it doesnt do it when i go somewhere turn the car off for a few minutes and then start it. any ideas or thoughts?
Old Feb 27, 2005
hotrodcivic2004's Avatar
my civic has no boost
hmm....see if yur muffler tip is rubbing against yur bumper...mine did that and annoyed the hell out of me. only vibrated when i did certain things. ALSO, check yur heat shield over yur cat, mine was bent once and would vibrate and also annoy the hell out of me, finally see if the axleback portion of yur exhaust is hitting yur sway bar or some part of yur frame where it bends over in the back. i had to minipulate that so it didnt vibrate. check that out and hopeuflly that'll solve yur problem
Old Feb 27, 2005
i had my axleback portion redone about 6 months ago cause it was hitting the sway bars so its not that. the heat shield isnt even on and 3 months ago i fixed the muffler so it would stop swinging back and forth in those rubber hangers, so it doesnt move. i can feel it under my seat when i start the car. i was thinking it might be the cat hitting something or moving. i dont know
Old Feb 27, 2005
hmmm......i dunno....make sure the midpipe is bolted tightly to the cat? makesure everythings tight i guess. see the clearance. i dont know what else it could be
Old Feb 27, 2005
yeah i should do that, im sure i got all that tight, but you never know
Old Mar 3, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
hey, thats what you get with megan racing cheap quality dirt cheap products. I use the same and have the same. I unlike you can take the rattling because its not much rattling, just a little shaking. Just get used to it or put it back to stock. Its probably cuz the mr testpipe doesnt have a cat more air.. u could always try bending the pipe but I would leave it cause its no biggie.
Old Mar 3, 2005
you dont know nothing about me and what i can handle. so how about you keep your mouth shut if you dont have any good advice. also dont forget that you have the same cheap quality dirt product that i do.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
