Can't jump start??
Old Feb 26, 2005
Can't jump start??
I tried, and failed, to jump another car today. This is the second time. Is it because our batteries are too weak? I though as long as the dead car gets 12v it can start. Both cars I tried to jump had a v6 engine does that matter or do our cars just suck. I have an optima yellowtop battery (slightly more amps than stock).
Old Feb 26, 2005
cambo's Avatar
I wish I was asian
was your engine running as well?
Old Feb 26, 2005
Well ya and I was revving it too holding around 3k. The other car would crank (it didn't before) but not start. I monitored my voltage with vafc and it never went below 13v even tho my lights were dimming inside.
Old Feb 26, 2005
pon55's Avatar
All ya can do by jumping is make it crank!If it woun't start thats another problem!
Old Feb 26, 2005
cambo's Avatar
I wish I was asian
maybe his starter was also dead.
Old Feb 26, 2005
Nah it was fine before. His girl had drained the battery by listening to the new system he put in with the car off.
And in the first car I tried before, it just had a dead battery. I mean that's what jump starting is for I thought. But I guess we don't have enough cca or something even with the car on. Strange.
Old Feb 26, 2005
CivicNavigation's Avatar
CivicNavigation is an unknown quantity at this point
Typically what I have found is that the cables I was using couldnt make a good enough contact on both bateries to transfer enough current to produce the amperage for the starter. The batter can turn the V6 no problem and with the engine running the voltage can stay up. I recently was jumping my Jeep off of my GF's 4cyl and after I wire brushed the terminals it cranked over no problem. Before it would show voltage but when i turned the ket the starter would barely turn. So check the teeth on the jumper cables clamps for corrosion, clean both terminal, and the ground point on the chassis of the car being jumped. To turn that starter you need a lot of current so you need a good contact.
Old Feb 26, 2005
Yup my terminals were clean, so were his because they just installed the stereo system. Jumper cables looked fine too so I dunno?
Old Feb 26, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
when I have problems jumping I usualy just jump both batteries together instead of using a chassis ground. I think its supposed to be dangerous this way though.
Old Feb 27, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
^^ yeah me too...I have trouble getting a chassis ground a lot, especially on new cars...everything is coated with paint.
Old Feb 27, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Next time, turn the headlights on in the dead car. Move and reset the aligator clamps until you get the brightest possible shine from the previously dead headlamps. Turn the Headlamps off, Wait a couple of minutes and crank the dead car over.
Old Feb 27, 2005
Regularjoe's Avatar
Regularjoe is on a distinguished road
Yes, generally its hard to get a true good connection. In my experience, connect the cables and let your car idle for a minute or two. This will allow their battery to charge some. Then try to start the car. Between the cables and the little power their battery charged it should start. I have never actually seen anyone just start a dead car w/o waiting a couple minutes for the dead battery to charge some .....
Old Feb 27, 2005
Ya okay I waited for 5 mins, revving for a minute at a time to charge it. Didn't help. All connectors were shiny new.
Old Feb 27, 2005
LiKEaFeRiO's Avatar
That's odd...I think the dead cars might have problems if it's cranking but not starting.
I've jump started Explorers and other vans/suvs with no problems when I had my stock battery (which was also powering 2 large amps + foglights + hids)
Old Feb 27, 2005
shmik1's Avatar
I agree with everyone else who said its prolly a bad connection, when I had a bad battery and my dad jumped mine it took a couple re-connects to get it, once it did... started right up.. so u should have just kept trying to reconnect a couple times... we had to adjust the clamps on both batteries a few times..
zaboomafoozarg
May 30, 2015 09:21 AM
dragonsblood
Apr 27, 2015 12:28 PM
SSMatey
Apr 13, 2015 06:09 PM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
black2k1vtec
Dec 6, 2001 09:49 PM
