nitrous
I wish I was asian
check out nitrous express, edelbrock, NOS, or ZEX. They all make universal nitrous kits.
You should get anything from a 25 shot to a 75 shot, with 75 shot being more risky to your motor. You should also get a window switch.
A bottle warmer, remote bottle opener, and purge kit are all nice accesories you can get later if you want.
http://www.7thgencivic.com/forums/sh...d.php?t=100899
If you have around 500 bones to spend, go buy yourself a wet kit from a reputable seller on ebay. All the kits are basically the same. Do you want a press button to shoot the nitrous or do you want a toggle switch that activates onle when you accellerate?
imo from what people have ran (times) like thiscrackertam (14.2 or 14.3) on this site i think its worth it. Plus some kits can be used on other mtrs like the nx universal wet kit. So if you wanna swap a k20a2 later u can use the same nitrous kit on that too
AKA Mr. 60ft. Not to be confused with Civic_Redline
Originally Posted by Civic_RedLine
you gotta be careful on the button one. You press it when you want so you gotta be at high rpms unlike my wot switch where I could be on 2k rpms and it still wont spray.
Originally Posted by 02CivicRider
whats a good setup of nitrous for an ex with intake and exhaust. and is it even worth it?
hey 02 dont get nitrous if you have a son and a wife. First, Im sure your wife wont ever let you use it with her in the car. Second, if anything ever happends and your sons inside the car, your responsible. Third, definately get the kit if the car is for your personal ride and no one else rides with you.
i would recomend a direct port kit over a wet kit.
due to the intake manifold desigin, there is a chance that fuel can puddle at the bottom of the intake manifold if you use a wet kit with a single intake pipe mounted wet fogger. when fuel puddles in the intake manifold, it makes it more prone to nitrous backfires, witch, is never a good thing. especaly when the intake manifold is made of plastic.
If you using your nitrous correctly, at the correct RPM's, You wont have to worry about puddling. All the cases ive heard of with blown-up intake manifolds it was because they were spraying under 3000 rpm.
I would never recommend a direct port unless the motor was built for nitrous. Besides who would do a direct port with anything less than a 120 shot.
yeah, ive seen direct port at the nitrous shop and god damn. He has like 6-8 nozzles for nitrous shooting in each cylinder. crazy ****. I asked how many shots he was running. If I remember correctly around 250 shot. He only uses it in the track though so thats good.
ditto that...you got rep points for that one kid...
you can jet it for whatever you want. as little as a 10 shot per cylnder. just because its direct port dosent mean its race only.
and your right, people SHOULDNT spray below 3000 rpm but some people do anyway.. a direct port is just a safer way to go.
crowtoo
May 11, 2015 06:50 PM
2k2civicballer
19
Apr 26, 2002 01:57 PM
