nitrous
Old Feb 23, 2005
02CivicRider's Avatar
02CivicRider is an unknown quantity at this point
nitrous
whats a good setup of nitrous for an ex with intake and exhaust. and is it even worth it?
Old Feb 23, 2005
cambo's Avatar
I wish I was asian
check out the nitrous FAQ.
Any wet kit should be good for you.
Old Feb 24, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
do you really want it?
Old Feb 24, 2005
yeah i really want it.
Old Feb 24, 2005
cambo's Avatar
I wish I was asian
check out nitrous express, edelbrock, NOS, or ZEX. They all make universal nitrous kits.
You should get anything from a 25 shot to a 75 shot, with 75 shot being more risky to your motor. You should also get a window switch.
A bottle warmer, remote bottle opener, and purge kit are all nice accesories you can get later if you want.
http://www.7thgencivic.com/forums/sh...d.php?t=100899
Old Feb 24, 2005
im stock now! T.T
If you have around 500 bones to spend, go buy yourself a wet kit from a reputable seller on ebay. All the kits are basically the same. Do you want a press button to shoot the nitrous or do you want a toggle switch that activates onle when you accellerate?
Old Feb 24, 2005
i was thinking of the botton because im going to put a new steering wheel on.
Old Feb 24, 2005
allmotor's Avatar
nor cal 7thgens
imo from what people have ran (times) like thiscrackertam (14.2 or 14.3) on this site i think its worth it. Plus some kits can be used on other mtrs like the nx universal wet kit. So if you wanna swap a k20a2 later u can use the same nitrous kit on that too
Old Feb 24, 2005
thats cool. i was thinking of doing the k20a2 swap late this year when i come home from deployment
Old Feb 25, 2005
im stock now! T.T
you gotta be careful on the button one. You press it when you want so you gotta be at high rpms unlike my wot switch where I could be on 2k rpms and it still wont spray.
Old Feb 25, 2005
yeah i heard about that. its not something im going to use a lot. maybe every now and then and just for fun
Old Feb 25, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
If you wire it in series with a window switch and WOT it should prevent any pooling/damage. Kinda how I'm gonna do mine if and when I do get the NX kit. I already posted my sleeper idea and a wiring diagram in another thread. Now I just need to get home, get a kit, and see if I can make it happen.
Old Feb 25, 2005
im stock now! T.T
if you get it, you will use it often... its so addicting.
Old Feb 26, 2005
im stock now! T.T
hey, you shouldnt get nos if you have a kid in your car. Its dangerous in the streets man. Just ge a new engine instead of risking other peoples lives.
Old Feb 26, 2005
BRCivic's Avatar
BRCivic is an unknown quantity at this point
yep. You will definitely use it more than you think - great fun
Old Feb 26, 2005
im stock now! T.T
hey 02 dont get nitrous if you have a son and a wife. First, Im sure your wife wont ever let you use it with her in the car. Second, if anything ever happends and your sons inside the car, your responsible. Third, definately get the kit if the car is for your personal ride and no one else rides with you.
Old Feb 26, 2005
bimmerjim®'s Avatar
bimmerjim® is an unknown quantity at this point
i would recomend a direct port kit over a wet kit.
due to the intake manifold desigin, there is a chance that fuel can puddle at the bottom of the intake manifold if you use a wet kit with a single intake pipe mounted wet fogger. when fuel puddles in the intake manifold, it makes it more prone to nitrous backfires, witch, is never a good thing. especaly when the intake manifold is made of plastic.
Old Feb 26, 2005
Logan3024's Avatar
If you using your nitrous correctly, at the correct RPM's, You wont have to worry about puddling. All the cases ive heard of with blown-up intake manifolds it was because they were spraying under 3000 rpm.
I would never recommend a direct port unless the motor was built for nitrous. Besides who would do a direct port with anything less than a 120 shot.
Old Feb 26, 2005
im stock now! T.T
yeah, ive seen direct port at the nitrous shop and god damn. He has like 6-8 nozzles for nitrous shooting in each cylinder. crazy ****. I asked how many shots he was running. If I remember correctly around 250 shot. He only uses it in the track though so thats good.
Old Feb 27, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
ditto that...you got rep points for that one kid...
Old Feb 28, 2005
bimmerjim®'s Avatar
you can jet it for whatever you want. as little as a 10 shot per cylnder. just because its direct port dosent mean its race only.
and your right, people SHOULDNT spray below 3000 rpm but some people do anyway.. a direct port is just a safer way to go.
ttamrekab
Sep 28, 2015 01:22 AM
crowtoo
May 11, 2015 06:50 PM
MamaBear2015
26
Apr 16, 2015 11:08 PM
2k2civicballer
19
Apr 26, 2002 01:57 PM
supermex
Feb 1, 2002 09:05 AM
