Sponsored by:
Sponsored by: CARiD
Hyper Voltage System
Old Feb 16, 2005
Nacho4750's Avatar
Nacho4750 is an unknown quantity at this point
Question Hyper Voltage System
I am planning on getting a HVS soon(like tomorrow) but what is the difference between SUN's Type MR and their new one the HVS GT(Hot Inazma Hyper in Japan) and is it worth the extra 30 or 40 bucks for the GT
Old Feb 16, 2005
jakejham's Avatar
jakejham should not be trustedjakejham should not be trusted
if it looks better then its worth the extra, if it looks the same then its not
Old Feb 16, 2005
SmiteSwift's Avatar
SmiteSwift is an unknown quantity at this point
I am looking too, but I thought I'd get the cheaper one, and use the extra money toward the hyper ground to go with it.
Am I wrong or do you need both Hyper Voltage AND Hyper Ground?
http://www.robearracing.com/pd_hyper_voltage_system.cfm
Look at the Apexi one while you're at it. It includes the voltage and ground in one package, and a bit cheaper.
http://www.robearracing.com/pd_apexi_super_ground.cfm
Old Feb 16, 2005
wonderz's Avatar
wonderz is on a distinguished road
you don't NEED both but its better to have it i guess.
i heard good review of the hyper voltage system, not sure about the Apexi tho. but pretty sure they both do about the same thing...
Old Feb 16, 2005
Nacho4750's Avatar
I know you don't need both, they just work better together from my understanding of it all. I don't know anything about the APEXi one though. I will look into it
Old Feb 16, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
you could have the same thing for 40 bucks... if you make it yourself.
Old Feb 16, 2005
wonderz's Avatar
you wanna show us how to make a hyper voltage system?
you know it is not only just grounding wires, right?
Old Feb 16, 2005
Blahman2's Avatar
it does the same thing
Old Feb 16, 2005
wonderz's Avatar
whatever u say.
Old Feb 17, 2005
opto_isolator's Avatar
Get a huge *** 20-25 volt capacitor and hook it up to your battery....
Voila - hyper voltage system.
Old Feb 17, 2005
Ya that's basically it. Get the MR the others are just different versions of the same thing with ground wires already attached. You can buy some wire and upgrade the factory grounds later if you want. It's not a must.
Old Feb 17, 2005
shmik1's Avatar
Originally Posted by opto_isolator
capacitor
it's a little more than just grounding wires
Old Feb 20, 2005
wonderz's Avatar
why high voltage capacitor? aren't voltage for cars is somewhere around 12-14v? also doesn't capacity go by farad instead of volts? i guess u mean a 20-25 surge capacity for the cap.
and gearbox, u got the MR right? do u know what's the spec of the capacitor inside that thing?
Old Feb 20, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
you know what it might not even be worth it cuz like the lowest i would suggest is 0ne Farad with maximum operating voltage of like 50v (it really doesnt matter what voltage it is as long as its not less than 20v) and one farad caps cost a lot
Old Feb 20, 2005
Addicted To Boost
you know what on second hand you might be better of with a cap http://www.onlinecarstereo.com/CarAu...roductID=14310
Old Feb 20, 2005
Addicted To Boost
http://www.onlinecarstereo.com/CarAu...roductID=13756
or go crazy, but you might be pushing your luck (16v) http://www.onlinecarstereo.com/CarAu...roductID=13755
Old Feb 20, 2005
wonderz's Avatar
but how many farad is in the MR voltage system tho.?
... and yea if u get anything higher than 1 farad, it would cost about same as just buying one of those voltage systems.
Old Feb 20, 2005
Addicted To Boost
not really you can still get like 2.4farad for 90 bucks and im not sure how many farads is MR rated at
Old Feb 20, 2005
zachgeyer's Avatar
a systems are already ok
Old Feb 21, 2005
20-25 volts due to surging - if you get a 12v cap you will burn it out.
However, the closer to the actual voltage you will run the better - as the larger the voltage, the slower the recovery time and the less benefit you will see (if any).
Caps are rated in farads - but that's their storage capacity. They also have a working voltage. And you definitely need a charging ressitor when charging it - cuz that sucker acts like a current sponge, and will fry something else with a surge if you don't slowly charge it, especially anything over 1F....
Old Feb 21, 2005
well whatever the thing is, it works. I felt a difference in throttle response and smooth acceleration. I would recommend it.
Old Feb 21, 2005
wonderz's Avatar
yea, i was just trying to figure out a cheaper alternative to buying this.
Old Feb 23, 2005
xliquidx's Avatar
xliquidx is an unknown quantity at this point
anybody who has the hyper voltage system which 1 is the best ?
Old Feb 23, 2005
type MR multi-rev
Old Feb 23, 2005
zachgeyer's Avatar
i have spoon its nice
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
jzhartman
22
Jul 23, 2015 10:42 PM
