i need your help guys!!!!
Old Feb 16, 2005
Civic_Nation04's Avatar
Civic_Nation04 is an unknown quantity at this point
my friend drives a 2001 honda civic ex..and he needs to replace his air conditioning filter....who knows where that is locted??????
reply as soon as possible!!! thanks!!!
Old Feb 16, 2005
Havok2k1's Avatar
Wicked Pissah Admin
The hepa filter is behind the glove box. Drop it down and you should see it there. I think there is a DIY somewhere on here...
Old Feb 16, 2005
2K1Civic17"Gabe's Avatar
You have to take the glovebox partway off, so it sits down on the ground or almost. Than you will see a black box, and you can pull the first filter out by pulling I believe. Than there is a second one to the right of that, that you can get out after the first one is. There is a DIY around here, let me link you. Its pretty simple hold on a sec
Old Feb 16, 2005
cant find it, sorry. But thats what you do. There are 2 screws under th glovebox, take those off, and open the glove box (after the screws are off) It should fall, than you should see the black box looking thing. It is very simple. good luck
Old Feb 16, 2005
buck's Avatar
buck is an unknown quantity at this point
if you look in your car manual it is in there i saw it in mine the other day when i was going through it.
Old Feb 16, 2005
thanks
Old Feb 17, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
You don't need to unbolt the glovebox. Just take the little tabs out of the back of it and it will swing all the way foward. Then take the little cover off of the black thing behind it, it just snaps out. The filters will be in there. Pull the first one straight out and then slide the other one over and out.
Old Feb 17, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Tell your friend it's in the manual.
LSC
Jun 22, 2015 11:29 PM
nufc
Legal Questions and the Law
Jun 21, 2015 09:57 PM
Reginator
Jun 17, 2015 07:54 PM
wsking77
Aug 29, 2001 05:34 PM
