Sponsored by:
Sponsored by: CARiD
quick question on springs?
Old Dec 29, 2001
CIVICINJEN's Avatar
CIVICINJEN is an unknown quantity at this point
if i get a set of springs, do i have to ge a camber kit or can i just ride without them. also im not going to go any lower then 1.5 so i can use my stock struts right?
Old Dec 29, 2001
Cypher's Avatar
Cypher is an unknown quantity at this point
no need for camber kit... stock struts will do for a while but then will blow and then you'll need new ones. Stock seems a little more harsh to me
Old Dec 29, 2001
1973's Avatar
1973 is an unknown quantity at this point
you wont need a camber kit with a 1.5 inch or less drop...the mcpherson fronts don't bend inward like the wishbones so no worries about the front, the rear will not turn far enough to cause any quick tire wear.....as far as shocks, you should be able to go for a long time with your stock set-up if your going down 1.5 or less....
Old Dec 29, 2001
acura2001el's Avatar
acura2001el is an unknown quantity at this point
yups, true true. No camber kit. Car isn't low enough.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Sep 26, 2023 06:44 PM
NoobyKid
Jul 13, 2015 07:53 AM
Ccoop87
Jul 9, 2015 03:26 PM
