quick question on springs?
Rep Power: 0 quick question on springs?
if i get a set of springs, do i have to ge a camber kit or can i just ride without them. also im not going to go any lower then 1.5 so i can use my stock struts right?
Rep Power: 0 you wont need a camber kit with a 1.5 inch or less drop...the mcpherson fronts don't bend inward like the wishbones so no worries about the front, the rear will not turn far enough to cause any quick tire wear.....as far as shocks, you should be able to go for a long time with your stock set-up if your going down 1.5 or less....
09-26-2023 06:44 PM
Touge
07-18-2015 05:37 PM
Touge
Ottawa
07-18-2015 05:35 PM
NoobyKid
07-13-2015 07:53 AM
